my b20v dyno
not as much as the low compression and stock b16 cams. id say a switch to gsr cams will yeild better gains that getting rid of the cat. honestly the numbers arent far from what i figured they would be. dont believe everything you read on the internet about how everyone makes retarded power
moral is (to OP); dont worry about your dyno power, as long as you are tuned and your car is running fine all the way up the rpms
wtf those are rather horrible numbers...
at least you know where your at & can only go up from here.
b20 8.8 or 9.7cr should be at +125tq.
Maybe the rings are starting to go and your loosing some compression.
GSR cams would be nice upgrade considering they are only $30-50.
waiting for someone to say:
"....pfff...don't worry about the dyno bro # take her to the track to see what she traps!
when you've done 90% of what you can to a motor based on your budget and power goals, then traps are more important than dyno#. But before you even compare traps, make sure she's not running hurt.
thanks for your input everyone. i did neglect to mention there was white smoke coming outta the exhaust during the session.. so the rings are starting to go..
namewasdallas
11
Jan 11, 2009 08:41 PM
b19coupe
24
Mar 31, 2007 04:03 PM
Boostage
May 19, 2006 05:26 AM
confusatron
Mar 25, 2006 12:23 AM
