Crx axle seal problems.
Old Dec 3, 2013 | 05:05 AM
suburban_ninja's Avatar
Default Crx axle seal problems.
Ok so some of you may know I did a d16z6 swap in my 1990 crx si. Well I have a axle seal leaking issue. I used the same trans and axles that came out before the engine swap. I replaced the output seals on the trans for the axles during the rebuild for preventive maintenance. The pass side is fine no leaks. The driver side I have put 3 oems and 1 timken in and all 4 leak terribly. They fit the case perfect and I installed them gently with the lip flush with the case. Well on my 4th seal I got smart enough to slide the seal on the axle out of the trans and the seal is to big of a inner diameter to fit around the axle shaft so there is the problem. I do not have the old seal because it got tossed I did a bottom up rebuild and to be honest axle seal was on the bottom of my worry list. So my question is anyone else had this exact problem? Do I have a swapped trans I don't know about? "Label is L3-xxxxxxxx" will need to verify remaining digits when I get home. Or is this a cheapo axle that maybe has a different size seal mounting surface. I have been using this seal.
Thanks in advance for any help.
Old Dec 3, 2013 | 05:14 AM
Freemananana's Avatar
Default Re: Crx axle seal problems.
Maybe you can get a seal at the parts store that will work. It just needs to be 'thicker' right? Seems like it is something weird with the seal you are using. Or maybe the axle is poop itself. Have you tried a new axle? I would just take your axle and the seal to a parts store and try and get one that fits around the axle but is the same outter diameter as the one you have.
Old Dec 3, 2013 | 05:33 AM
Yea that was my last resort idea. Just checking here first that there are no known issues like I'm having. I'm guessing mine is a one off fluke pissing me off that the whole engine build went like butter and I can't drive it because of a damn axle seal lol.
Old Dec 3, 2013 | 06:21 AM
Yeah. I have a similar issue and it sucks. It's always the little things.
Old Dec 3, 2013 | 08:06 AM
jlicrx's Avatar
sounds like you might need 91205-PL3-A01
Old Dec 3, 2013 | 08:45 AM
tonekids's Avatar
MistaBone has drummed this into my head by now, and I'm not even at that point in my restoration.
I am copy/pasting my notes that I have been assembling throughout the year: This, I believe, I copied from one of MistaBone's postings from either here or CRXCommunity:
No, you ordered the wrong seal. You trusted Honda parts catalog and did not listen when I said to order seals for 92-95.
Si DS axle seal is listed incorrectly, it is for the ZC/RTAWD, B01 is the last three.
A01 is the correct seal for ALL D series USDM FWD 88-2000. It also fits 94-01 B series trannys.
So just to clarify...
The correct Honda part # for the left (driver's side) axle seal is "91205-PL3-A01 OIL SEAL (35X56X8)"
The incorrect Honda part # is "91205-PL3-B01 OIL SEAL (40X56X8)"
91205-PL3-A01 Left/Driver
91206-PL3-A01 Right/Passenger
Old Dec 3, 2013 | 09:07 AM
24TEN's Avatar
PHANTOM MENACE
This is some GOOD info.
Old Dec 3, 2013 | 09:26 AM
Well then. This guy knows his stuff. Try this out for sure. Seems like it should be fixed shortly!
Old Dec 3, 2013 | 10:17 AM
Tone you da man I'm getting this **** seal tomorrow. Hopefully it is good thanks for the awesome info. I'll post update once I get in there.
Old Dec 3, 2013 | 03:51 PM
So as of now tone's info is correct. Seems like everything is holding up now. I'll check back and make sure everything looks good later and if anything changes I'll report back details.
Old Dec 9, 2013 | 08:18 AM
tonekids's Avatar
Awesome!
Please don't credit me. I just checked my notes for this, knowing at some point in time I saw this very subject discussed, and "MistaBone" had the correct info.
Old Dec 9, 2013 | 08:30 AM
Awesome!
It's been a week and he hasn't checked back in, so I assume it is fixed for now. That's quite impressive. Your notes? Do you actually keep hand written notes on this sort of stuff? Or book mark threads or something?
Old Dec 9, 2013 | 09:07 AM
tonekids's Avatar
I have a folder on Google Drive with subfolders for the various systems. Each subfolder then has a bunch of junk in it like pictures, thread links, and some copy/pasted text info. This particular thing I took note of way back when and copy/pasted the relevant stuff into a Google Doc.
It really is amazing how much great information there is in this forum. Without things like H-T, I would never, ever have started working on cars.
Old Dec 9, 2013 | 10:16 AM
I would almost agree, except I started working on cars before I found H-T. Shop manuals and the parts store is where I started. But the internet makes everything so much easier. Trouble shooting is much easier with the wealth of knowledge available through google.
Old Dec 9, 2013 | 12:52 PM
Scott@SonsHonda's Avatar
Icon6 Re: Crx axle seal problems.
http://parts.sonshonda.com/products/...6-PL3-A01.html
• Passenger (right) side axle, Oil Seal (35 x 62 x 8) - $9.77 each
http://parts.sonshonda.com/products/...5-PL3-A01.html
• Driver (left) side axle, Oil Seal (35 x 56 x 8) - $8.00 each
Just to add our site as for a resource for you: we like to help out those working on rebuild projects. Our parts page has exploded view diagrams that might help in case you are looking for a specific part – or send me a PM. I can get you to the item you might need.
Scott
Old Dec 9, 2013 | 04:28 PM
I usually don't like the spam nature of for sale stuff, but at least he directly linked it. It will be a very good addition to this when it falls into the achieves.
driveslow
19
Mar 5, 2009 07:03 PM
itsLOUiSduh
Oct 17, 2008 12:31 PM
hectic57
Jun 18, 2008 02:49 PM
ABK
Apr 8, 2004 08:48 AM
stealthhatch
Mar 19, 2004 10:19 AM
