FS: HKS T45S Turbo (700whp capable) $375
For sale is a used HKS T45S in good working condition. This turbo was the predecessor in HKS's turbo offerings to the T04R. I forget the size, but believe the compressor is around a 67mm. I'll remeasure the wheel again, but the turbo is supposed to be good for around 700whp. The turbine housing is an HKS exclusive T4 divided .90 A/R, and the rest of the turbo is a unit manufactured by Garrett Japan. This is supposed to use Garrett TA45 parts, so a rebuild should be super cheap (although this turbo does not need a rebuild, as it has ZERO shaft play). Wear includes small nicks on the edges of the compressor wheel, and some surface rust on the iron parts of the turbo. I have enclosed extreme closeups of the damage to the wheel, but it has not seemed to affect the turbo operation as the turbo has been run like this for a while without any increase in shaft play. $375 +shipping (located in Los Angeles, CA)
PM or email filaraki99@msn.com
Also includes 4 bolt flange for HKS housing.
Turbo O
May 29, 2008 04:23 PM
Rick Solis
Mar 26, 2004 12:51 PM
