94 Honda Civic Smoking?
Old Dec 2, 2013 | 05:11 PM
EGToFlyy's Avatar
Default 94 Honda Civic Smoking?
I have a 94 Honda Civic and when I turn it on and leave it to warm up (I let it warm up all the way) and when I go it starts smoking when I completely stop. About 5 minutes pass by and I stop again and the smoke is gone. What could be causing this to happen?
Old Dec 3, 2013 | 05:47 AM
EGToFlyy's Avatar
Default Re: 94 Honda Civic Smoking?
Any suggestions?
Old Dec 3, 2013 | 05:52 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
More information, where is the smoke coming from? What engine? Mods? does it smoke when you accelerate or when you stop(it is unclear from your first post)? Have you checked your oil to see if it is milky? Your coolant level? Any CELs(Check engine lights)? etc?
Old Dec 3, 2013 | 07:46 AM
EGToFlyy's Avatar
The smoke is coming from the exhaust. Completely stock D15B7 SOHC engine no mods. It smokes when I start it and leave it to warm up and than I go and when I come to a stop you can see the smoke. It's only when I start to drive it and than after about 5 minutes I come to a stop it stops smoking. My oil is good and my coolant level is good too.
Old Dec 3, 2013 | 08:03 AM
pityocamptes's Avatar
What color is the smoke? White, gray, black...
Old Dec 3, 2013 | 08:24 AM
instrument's Avatar
either burning coolant,oil, or its winter and its normal.
open your radiator cap when you start the car and let it warm up, if it bubbles and spills over then its your head gasket
Old Dec 3, 2013 | 09:07 AM
EGToFlyy's Avatar
I believe it's white.
Will try that "instrument" when I get off of school. Thanks guys
Old Dec 3, 2013 | 10:06 AM
VeganEJ8's Avatar
Could always do a good ol fashion compression test?
Old Dec 5, 2013 | 08:13 PM
maksmizer's Avatar
get rid of it asap
Old Dec 5, 2013 | 08:35 PM
slowDB7's Avatar
∆ care to elaborate on that reasoning?
Old Dec 5, 2013 | 09:44 PM
EGToFlyy's Avatar
Originally Posted by maksmizer
get rid of it asap
Get rid of what? The engine?
Old Dec 20, 2013 | 09:32 AM
maksmizer's Avatar
the car
why?
less hassle to buy another car than to deal with a blown engine
Old Dec 20, 2013 | 10:29 AM
B_Swapped93's Avatar
the car
why?
cause smoke mean's it "done" stop making crap up, there's enough ppl doing that already. OP it's more they likely just the winter taking it toll, and if it is burning some coolant/oil it's an old car it'll do that if it's not eating oil like crazy etc just leave it.
Old Dec 20, 2013 | 10:46 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
White means water but not necessarily coolant.
After you drive the exhaust is hot and the air will condense water inside of it once you park. Once you start and warm the car up the ewill burn that water off but it can take it a little while. If it's a head gasket and it's blowing steam (white smoke) it won't be a little, it will be a lot of "smoke" and it won't matter the tempurature outside. Also it will be everytime you accelerate it will be at it's worst, not just once and then go away.
If the smoke was blue that would be oil and if it was black it would be unburnt fuel or running to rich.
During winter especially it takes even longer for the exhaust to purge all the water.
If you look at other cars exhaust in the mornings you can quite often see the water draining out.
It's common, don't worry about it, just monitor your coolant levels and condition and oil levels and conditions and the car should last you just fine.
Of note, the D15B7 used a graphite headgasket and they are known to go over time. But you will see coolant levels drop, plumes of white smoke and or milky looking oil and a severe loss of power when it does.
I've heard of some guys driving a year or so with a leaking head gasket they just kept topping up the coolant with water daily until the thing finally died.
Old Dec 20, 2013 | 09:30 PM
EGToFlyy's Avatar
Yeah I do believe it's burning some oil (since it is almost a 20 year old car) and the temperature that it suddenly dropped to be cold. It's just until the car warms up and I drive around the block it smokes but after I drive it for about 3 minutes the smoking stops.
Really appreciate the relevant comments. Thanks
Old Dec 21, 2013 | 09:16 AM
Redlining206's Avatar
I actually have the same problem with my 94 civic and I'm going to change the thermostat and head gasket today. Hopefully it works. Did you ever change the gasket?
Old Dec 22, 2013 | 08:09 AM
EGToFlyy's Avatar
I did not. I was just thinking of doing a whole engine swamp. Let me know if works by changing the gasket and thermostat
Grif
19
May 7, 2015 05:17 AM
xprohx
Apr 30, 2013 10:01 AM
honshu
Jun 9, 2012 10:36 AM
Honda_ThuGZ
10
Feb 14, 2008 03:18 PM
djstain
Jun 1, 2006 09:58 PM
