battery light
Okay so I was driving today nd I Noticed my battery light came on and went away. Now im sitting in my car and turning the wheel nd the light keeps coming and going. I dont wanna play games nd replace my battery, altinator nd belt. Can someone tell me what it is please
Start by check your belt tension and condition.
Then with your engine of with a voltmeter set to 20 v check the voltage in the battery it should be more or less 12.2v to 12.6v
finally repeat the same but with the engine running you have to see 14.something.
From experience it's usually the first sign of a bad alternator. Do as "carlos8" stated and perform those tests. Alternately since your car is still drivable you can take it to your local parts store and ask if they can perform the tests for you (it's free in my area, whether the alternator is on the car or removed they can test it).
bleedblue94
May 20, 2006 07:57 PM
ch4nq
Jul 20, 2004 07:02 PM
