Bad miss; stutter; hiccup
Old Dec 2, 2013 | 01:15 PM
Root16's Avatar
Default Bad miss; stutter; hiccup
Recently, my 1992 Civic VX started to have a stutter. Noticed it first at low rpms, now it does it at most all rpms, but definitely much worse at low rpms. It's gotten really bad that I don't want to drive the car. It seems to be worse when it's wet out, but now it's doing it all the time. When the engine is cold it does not do it at all. It's only when the motor has been up to temp for a bit that it starts to do it, so I would say it's temp related. It was also just now blowing white smoke. It's never done that before. However, I recently got an oil change at Mavis and the guy wanted to use some oil he preferred/recommended and I allowed him to, but then realized I had put Mobil 1 which is a full synthetic in a couple oil changes ago, and the oil the Mavis guy used is non-synthetic. It's possible the white smoke was condensation burning off (there was quite a bit of moisture on the end of the tail pipe while the car was idling) but the smoke was fairly thick. I'll keep an eye out for drop in oil/coolant, but there hasn't been up to now (there was some oil loss awhile ago during some rigorous driving, but none recently).
My mechanic told me the miss could possible be one of the following things:
1. something to do with the ignition system; the rotor, cap, plugs or wires, but given that all were replaced a year ago, it'd be disappointing if they were failing again now. He also said it could be one of the modules inside of the distributor I believe he said.
2. fuel pump or something with the fuel system.
3. chipped tooth on the timing belt? or misaligned or something wrong with the timing belt.
Any other ideas?
Thanks.
Old Dec 2, 2013 | 01:24 PM
pityocamptes's Avatar
Default Re: Bad miss; stutter; hiccup
Do you have a milky consistancy in your oil (ie water in your oil)? If so you have coolant leaking into an oil galley.
Pull your plugs, check to see if a plug looks clean compared to the rest, and if the piston head also looks abnormally clean. If this is the case you have a head gasket leak with coolant dumping into the combustion chamber.
Andrew99911
Honda Civic (2001 - 2005)
Jul 5, 2017 11:46 AM
Loverice
Jul 18, 2014 11:47 AM
Kylehugo
68
Apr 13, 2012 07:50 PM
accord1986
Apr 5, 2012 02:22 PM
VTEC_PRODUCTION
Nov 5, 2007 10:31 AM
