PW0-X00 How much money
Old Dec 2, 2013 | 08:02 AM
andrija's Avatar
10 Year Member
Default PW0-X00 How much money
ECU
I'm running this chip
SST 27SF512
70-3C-PGE
0746084-C
ECU came with B16A1 swap
, and i want it out, because upper rev limit (RPM)
My engine is stock..
I am afraid that my engine does not
Is it possible to make changes on PWO X00 bin,
like this:
VTEC : 5000 tr/min
Rupture : 8500 tr/mn
Shift Light : 8000 tr/min
LAUNCH CONTROL
How much money cost to me, that one of you make this bin?
my email: andrijahonda@yahoo.com
Thank You in Advance
Old Dec 2, 2013 | 09:51 AM
GhostAccord's Avatar
Default Re: PW0-X00 How much money
• Phearable.net
Old Dec 2, 2013 | 02:03 PM
andrija's Avatar
10 Year Member
tnx but OBD1
Old Dec 2, 2013 | 02:27 PM
They might be able to do up an OBD0 map for you. Never hurts to ask!
Old Dec 27, 2013 | 01:35 AM
andrija's Avatar
10 Year Member
Does anyone have bin, with shift light and launch control for ECU PW0-X00, obd0, B16A1.
Old Dec 28, 2013 | 07:36 AM
andrija's Avatar
10 Year Member
Here in this topic, you can upload your bin file, maybe still someone look for the same folder as I..
My email: andrijahonda@yahoo.com or andrijahonda@gmail.com ....
I sent a inquiry to a few forums with the same question for the bin folder .. Specifically to:
http://www.civic4g.com/
http://forum.pgmfi.org/
https://honda-tech.com/index.php
http://www.maxrev.de/forum.htm
http://www.clubcivic.es/
And I'm still waiting for answers.. :idea:
My engine is stock, without modifications .. I have only 5.5kg flywheel and a diameter fi 60 exhaust..
I would like bin folder that is similar to the OEM map .. I want to have this: shift light, launch control, safe mode VTEC, VTEC slightly lowered and slightly raised blockade..
I think on OEM EDM base map set this:
vtec: OEM 5300
launch control: 5000
blocade:8200
shift light:8000
I'm trying to do something in the BRE program ... But do not get it .
I know the mechanics and electronics, but not get it programmed in BRE..
I love old junk back on the road..
my project http://www.civic4g.com/index.php/forum/ ... 10&t=13528
I guess some bin map would come out.. I have a friend who has an EPROM burner, but he has never worked in the BRE. For burn bin folder on the EPROM is no problem..
Old Dec 29, 2013 | 06:58 AM
andrija's Avatar
10 Year Member
I received a map from friend: Lee madfablab.com
Bin map is at this link:
https://www.dropbox.com/s/4nvwdad5ih...-madfablab.bin
PW0-JDM modified:
Stock fuel/timing maps
Revlimit to 8200
Launch control 4000
o2 sensors both enabled
Speed limiter disabled
Checksum disabled
Knock disabled
VTEC moved to 4500rpm
VTEC vss/temp/cel/presssure checks disabled
Shift light at 8000rpm
Golden Eagle
Performance
Nov 21, 2010 08:10 AM
the ghoul
Engine Management and Tuning
Oct 19, 2010 02:16 PM
Golden Eagle
Performance
Oct 19, 2010 08:17 AM
Golden Eagle
Performance
Oct 1, 2010 10:55 AM
Golden Eagle
Performance
Oct 1, 2010 09:44 AM
