Oil pan bolts missing?
Old Dec 1, 2013 | 07:42 PM
jayupark's Avatar
Default Oil pan bolts missing?
I noticed a small puddle of oil under my car so I did a quick inspection, the oil pan had oil leaking out of it... bad gasket or just bolts that were too loose?
Also, from the attached pic. Am I missing 2 bolts? All the other bolts/nuts were super loose, they could easily be loosened by hand (a couple of them moved at the touch)
I tightened the bolts about a 1/4 turn tight (after hand tightening) since I did not have a small/low torque wrench. Do you think that is too tight?
Old Dec 1, 2013 | 08:16 PM
B_Swapped93's Avatar
Default Re: Oil pan bolts missing?
if the other were loos good chance that the missing ones were shook loose, get 2 new bolts. No that's all I tighten mine to stands up lots of vibration,
here's the Honda part number 95701-06018-08
Old Dec 2, 2013 | 07:31 PM
jayupark's Avatar
Thanks. Tightening seemed to have worked
Old Dec 3, 2013 | 06:07 PM
TOO MUCH TORQUE's Avatar
same happened to my car....really weird but mine wasnt leaking. Bought some new nuts at honda and re-torqued it to spec.
Fred Dukes
Apr 29, 2017 02:48 PM
94 IntegraLS
Sep 20, 2013 06:54 AM
RTW DC2R
Jun 25, 2006 04:26 PM
O16581724 5 2 5
13
Aug 2, 2005 04:49 PM
