I bought someone else's project
Old Dec 1, 2013 | 06:16 PM
Rex-2000's Avatar
Default I bought someone else's project
90 CRX wB18A1 crank no start, new main relay new fuel filter start just fine w pyroil new plugs dizzy looks good getting spark to all cylinders new TPS
Old Dec 1, 2013 | 09:29 PM
jonGSR's Avatar
Default Re: I bought someone else's project
Wtf? This makes no sense.
Old Dec 1, 2013 | 09:52 PM
Rex-2000's Avatar
I have a crank no start situation and I'm stumped
Old Dec 2, 2013 | 03:08 AM
Freemananana's Avatar
It's cranking but not starting. Check the distributor plug wiring since it is a swapped motor. Could be wrong. Are you getting fuel? There could be a wiring issue. I suggest you check it all.
Old Dec 2, 2013 | 03:38 AM
coconutwater's Avatar
starter wired in correctly?
Old Dec 2, 2013 | 04:08 AM
EFcivicSEDAN's Avatar
check your basics.....spark and fuel...then work from there
Old Dec 2, 2013 | 05:02 AM
He said it's cranking and he has spark. That means it's probably a fuel issue. I would still bet it is the 2 white wires on the distributor being backwards. What trim level was the CRX originally? Was it DPFI or MPFI?
Old Dec 2, 2013 | 07:36 AM
Rex-2000's Avatar
Originally it was an HF
Old Dec 2, 2013 | 07:53 AM
Rex-2000's Avatar
The fuel pump works fine separated from the car so I changed the main relay I have spark across all cylinders and a new fuel filter
Old Dec 2, 2013 | 08:02 AM
jlicrx's Avatar
are you using the original HF engine harness?
Old Dec 2, 2013 | 10:39 AM
whited's Avatar
CRX God
What type of injectors are you using? Do they not require the resistor pack, but you still have it?
Old Dec 2, 2013 | 11:08 AM
Rex-2000's Avatar
Idk what harness it has and I think the injectors are stock LS teggy
Old Dec 2, 2013 | 11:25 AM
jlicrx's Avatar
if it doesn't have the HF engine harness, it will not work - look at the round 8-wire connector on the engine harness at the driver's side firewall connector - it should have wire colors and locations like the picture below - if not, it is not the HF harness
Old Dec 2, 2013 | 08:38 PM
Rex-2000's Avatar
It ran for a few days then one day it just stopped responding to throttle and refusing to idle I replaced the TPS calibated it and it ran just fine again then the same thing happened later that went back got a second new tps recalibrated it and now I'm here
Old Dec 2, 2013 | 08:40 PM
10psiLsEf2's Avatar
Have you done a compression test?
Is your timing belt broken?
Old Dec 2, 2013 | 08:42 PM
10psiLsEf2's Avatar
By anychance did you accidentaly mix up the map sensor connector with the tps connector? Theyre identicl and close to each other
Old Dec 2, 2013 | 08:52 PM
street_racer_271's Avatar
should still start if this is the case, idle would just purge
Old Dec 2, 2013 | 08:59 PM
10psiLsEf2's Avatar
Ive never seen this be the culprit abd the idle(purge) whatever that means. But ok
Old Dec 2, 2013 | 09:04 PM
Rex-2000's Avatar
It start with pyroil and I'm pretty sure I plugged in the tps cable and I haven't run compression test and timing belt is in tact
Old Jan 16, 2014 | 10:17 PM
Rex-2000's Avatar
Got it fixed it was the fuel pump
Arthas
Sep 2, 2010 06:42 AM
Corvair64
Dec 27, 2009 02:10 PM
Happy Gilmore
May 13, 2009 05:21 PM
themex77
Feb 16, 2007 08:58 AM
Eglifestyle
Sep 14, 2005 07:23 PM
