ITB injector mod ??
Hi,
Those look like OBX itb's. Are you trying to move the injectors spraying fuel after the butterfly plate as the OBX have them spraying fuel before the plate.
One thing would be better atomization and less fuel smell.
Jignesh
Jignesh
The post throttle plate injector location is better for fuel control across the power range and better for fuel economy. It would be the location much better suited for a vehicle that is used on the street.
The pre-throttle plate position is more useful in Mid to WOT conditions as it creates a better fuel atomization and the fuel has more time to mix with the incoming air and cool. In turn, creating a combustion chamber cooling effect. Best suited for a race application.
In a dual stage fuel injection system the post throttle location is used for low RPM and idle conditions where the butterflies don't open as far. Using this location keeps fuel from pooling on the butterflies and/or falling out of suspension. Causing drips of fuel to run down the runners into the combustion chambers. This can make it harder to tune. The pre-throttle injectors in a DSFI system are for higher rpm and higher load conditions where the throttles will be open wider.
Thanks for the info guys! I was unsure if this mod was a good thing or a bad thing. Im about to buy it and its now settled.
Very nice info GhostAccord, learned alot
thx
here´s some cookies for ya!
thxhere´s some cookies for ya!
hybrid_vtec
18
Feb 25, 2006 08:07 AM
