need help 1993 del sol injectors not firing
1993 del sol
ok here is what I have done...
have fuel pressure, have spark, have compression. del sol just cranks and cranks...
I can start it and run it on starting fluid.... Once in a while using starting fluid it will kick over and start running fine. runs and drives but if you shut it off and let it sit, same result.
I checked fuel rail for pressure and its good, pulled rail and turned it over and injectors wont spray gas.
what causes the injectors not to fire?
problem solved... not sure why but the ECU was bad I put in a used ECU I picked up last weekend and it fired instantly... took a minute to be able to idle and for the tach to work but now its purring like a kitten...
Bipolarcivic
30
Apr 10, 2016 07:26 PM
