Transmission & Drivetrain Gearboxes, Differentials, Clutches
Dropping Trans
Old Dec 1, 2013 | 09:19 AM
triggh04's Avatar
Default Dropping Trans
My last thread was about my brothers 95 Accord having Auto tranny issues, We got pretty lucky and found a 96 Tranny with 56K miles on it.
I have dropped many transmission in my time but all on old American cars. Is there any typical tricks or special concerns I should look for or take into consideration?
Also to fill to capacity the tranny takes 5 or 6 quarts? An only Honda oil correct?
Old Dec 1, 2013 | 11:57 AM
94EG8's Avatar
Seagull Management
Default Re: Dropping Trans
I don't think I ever did an Accord specifically, but on most Hondas one starter bolt needs to come out as it threads into the engine block (it's the long one, usually the bottom IIRC) and there's generally one bell housing bolt that goes in from the back IE engine side that's easy to miss.
Old Dec 1, 2013 | 06:04 PM
uberEFtuner's Avatar
What are you working on? I learned the hard way to drop the subframe on early 90s hondas. Crx/civic/accord. Only on a 5 speed can you weasle it out without droping the subframe,but I would anyway.
Old Dec 1, 2013 | 06:07 PM
94EG8's Avatar
Seagull Management
I've never dropped the subframe on a '92 - '00 Civic to drop a trans, and I have done a few automatics. I never pulled a trans on an Accord, but I've never heard of anyone having to drop the subframe either. The newer stuff, yes definitely.
Old Dec 2, 2013 | 02:52 AM
grjr's Avatar
You should consider flushing the trans cooler out if you can and also installing an inline filter so that your "new" trans has the best chance at living a long life.
'00Accordster
Apr 25, 2009 08:12 PM
BoostedH23Accord
Acura TL, RL & ZDX
10
Dec 10, 2008 05:08 PM
renzema
Mar 26, 2006 11:39 PM
Slow_import
Jan 11, 2006 08:16 PM
Art Vandeleigh
Nov 18, 2002 05:55 AM
