01 accord clutch nightmare! Please help!!
Old Dec 1, 2013 | 04:57 AM
Sealboy05's Avatar
Default 01 accord clutch nightmare! Please help!!
2001 accord. 4 cyl
Pedal would by rise from the floor, changed the slave because it was easiest component to reach. No fix. So changed the clutch master. Tried I bleed and the xring on the slave line adapter was leaking. Finally ordered one and put it on and rebled. It worked for for one day then same problem.
I have not been able to fin Anyone that has te same setup as this car. The bleeder sits right next to the front engine bracket and is not accessible with slave installed. So I have to instal the slave with a hose attached, bleed the slave and turn the bleeder closed with the hose then remove the slave and tighten the bleeder.
I am trying to figure out whether I need to put some white lith or something on that xring as I am afraid it is getting cut and failing because I have to turn it all those times to get it bled.
ns-export
Oct 22, 2017 08:45 AM
westcoastaccord
Jun 24, 2016 12:34 PM
Crazydad
Oct 30, 2013 10:51 PM
UserX
Jun 30, 2013 12:44 PM
spurge
Aug 21, 2007 12:53 AM
