P0505 IACV Malfunction need help, tried everything.
My 98 hatch with 100,000 miles is having the piece of **** IACV malfunction code.
The air charge sensor is fine.
ZERO air leaks anywhere.
Coolant is full and has been bled.
TPS doesn't seem to have any issues.
IACV has been cleaned and re-installed correctly.
I can drive the car for anywhere from 20-60 miles and it runs GREAT! No issues at all, idles and pulls like a dream. As soon as the CEL clicks on the car idles at a constant 1500 RPM, and when you let off or tap the gas the car bucks like crazy. I'm completely lost and want to end smash this car with a hammer. I literally drive around with my OBD2 scanner and erase the code to make the car run flawlessly when the car ***** itself.
I need help because I'm at the end of my whits. Thanks guys.
Edit: Could it be a bad throttle body gasket, and when the computer detects the vacuum leak it kicks the CEL on and tries to compensate, thus resulting in the high idle? I have a new one and I'm going to throw it on tomorrow.
You have an electronic malfunction of the IACV system. You have no power to the valve, no ground, or the solenoid is now an open circuit. This is NOT a mechanical malfunction at its root. That would have to be Idle system range/performance, which it is not.
Since you describe this malfunction as an intermittent condition, check the condition of the electrical connector pins for deformation, corrosion, or weak connection.
The air charge sensor is a sensor that plugs into the airbox on the d16y7. I've had it give me issues on other Civics.
Anyway, how do I go about properly testing the ECT and TPS with a multimeter? I want to do it once and do it right. Thanks for the guidance so far. Is there no chance of it being a mechanical malfunction due to the fact that it's intermittent and controlled by the CEL, per se?
Upon removal of the IACV for cleaning all sensors appeared to make a solid connection and click in firmly, however, what do you suggest I try, another IACV? Are you implying my connector on the IACV is damaged, or that the connector wire itself is damaged? Thanks again.
The IAT sensor generally would not cause an idle problem or throw code P0505.
When the engine is fully warmed up, unplug the ECT sensor and measure the resistance across the two terminals. It should read 200-400 Ohms.
Back probe the Red/Blk and Grn/Blk wire terminals of the TPS connector. Turn key to ON(II). Measure voltage with the throttle closed (0.5V) and wide open (about 4.5 V).
Alright, I'll be sure to do that tomorrow. My guess also lies on the idea of it being a sensor because it simply makes sense. Just trying to add to my to-do list, if those sensors appear to be functioning normally, where should I go from there?
A problem with any other sensor will cause a code related to that sensor, not the IACV. As the IACV cannot be accurately controlled without various inputs, such as throttle angle, coolant temp, etc, an IACV related code can only refer to the IACV circuit itself, which, will refer to a P0505 if using a generic scan tool. P1508 and 9 are Honda specific codes, there is no difference between them.
Honda triggers the IACV from the ground end, so ensure you have source voltage to the sensor connector. If that checks okay, I would substitute or test the IACV. If this does not fix the problem, substitute the PCM, as the PCM may not be grounding the IACV due to a defective transistor.
A carbon clogged IACV will throw P0505 (mechanical issue) but not P1508/P1509. Conversely, a problem in the IACV circuit (electrical issue) will throw P1508/P1509 but not P0505.
Therefore, your advice quoted below is wrong:
http://www.obd-codes.com/p0505
Tell me what part of that document is mechanical. This applies regardless of vehicle type.
This debate is over until you have read and understood the distinction between P0505 and P1508/P1509 in the 96-00 Civic service manual. After you do this, your error will be clearly evident.
P1508 and P1509 are not the trouble codes he listed, P0505 is, to the OP, diagnose what code you actually have. I am retiring from this thread until you bring forward results.
Anyway! I'll be running tests on both sensors tomorrow to ensure their functionality. If the problem persists I'll order a new throttle body to eliminate that, the TPS, and the gasket, as well as the IACV (likely from a low mile junkyard vehicle to save money, I planned on swapping this turd come spring, just need it to pass inspection.)
However, if a sensor proves to be malfunctioning (hopefully my case!) I'll jump right on that. Results posted tomorrow.
You have given bad advice in this thread because you are too arrogant to read the Honda Civic service manual.
Haven't erased the code yet. Car idles at 1500 steady with a warm engine and is throwing code P0505 IACV malfunction, so sounds like we're right on point.
Good. This^ makes diagnosing easier. Before you test the ECT and TPS, remove the air intake system when the engine is high idling, and then use your finger to cover the hole inside the TB leading to the IACV. Does the idle speed drop?
Hoping for a sensor failure to be evident, but we shall see come tomorrow.
Edit: What should I go about doing if the idle DOES drop when I cover that hole inside the TB? Does that indicate a failure in the IACV?
If the idle drops to normal or lower, then this rules out a vacuum leak, indicating that the IACV is causing the high idle by bypassing air to the IM. This bypass could be caused by an IACV mechanical malfunction, misadjusted idle speed, or a problem with ECT or TPS circuit.
