Coolant gushing from being motor/passenger side! Help!
Old Nov 30, 2013 | 02:38 PM
gooblinn258's Avatar
Default Coolant gushing from being motor/passenger side! Help!
I was in the process of bleeding and cleaning my cooling system using water. Well I have added probably 4 or 5 waterboytles full of water to my empty radiotor. I turn my car on to mix the water around and get ready to drain it when necessiary. I would rev the car up to about 4 or 5 rpm and water (as my coolant) was gushing out the back of the motor under intake manifold passenger size. I had just changed my IM gasket so maybe its sleeping out between head and IM? Or maybe a hose I can't spot is leaking. BTW I idle at 2 rpm and it will drop down to 1 then back to 2. Then after awhile it will go to 1.
Old Nov 30, 2013 | 02:53 PM
sirtef9's Avatar
Default Re: Coolant gushing from being motor/passenger side! Help!
There's 2 lines back there you could have left disconnected or broke upon removing.
Old Nov 30, 2013 | 03:02 PM
B_Swapped93's Avatar
you probably missed connecting one of the hoses, x2 check that they're all in place
guy_from_nerk
Oct 14, 2008 10:57 PM
NYCxTEG
Apr 2, 2006 12:05 PM
screen_name
Apr 30, 2005 05:54 PM
eternity0114
May 10, 2004 02:27 PM
