OBDO B series stuff
B series stuff for sale. All things are OBO. B16a head is rebuilt,new valves, new guides, resurface, etc.It comes with manifold,fuel rail,injectors,dizzy,cams, vtec solenoid, etc I will give you all the seals/gaskets too. Nothing is torqued so you can check it out. It has had port work in past. 600. B16a block. New rear main seal and oil pan seal. 300 Spins freely. B16a cable tranny needs new input/output seal 200. B series axles with half shaft for Crx 100. Dc 4-2-1 header, has dent at bottom,kinda beat up 60 bucks, has carb plate, b series starter and alternator 50 bucks each,Crx 3 inch intake 40. Some stuff not pictured. Located Woodland Hills 91367
n8 boostn 1bar+
Mid-Atlantic (Sales)
Feb 14, 2007 03:10 PM
