Copper Spark Plugs for GS-R?
Old Oct 27, 2002 | 07:54 PM
araknis's Avatar
New User
Default Copper Spark Plugs for GS-R?
I couldn't find this topic discussed under the search so here it goes.. Can copper plugs (NGK) be used in a GS-R safely/effectively? Any difference in performance or anything? Also, what is the model number that will do the trick?
Old Oct 27, 2002 | 10:37 PM
Weston's Avatar
Default Re: Copper Spark Plugs for GS-R? (araknis)
Yeah, copper plugs will work, but they won't help your performance any. Platinum plugs are actually mostly copper, but the electrode is coated with platinum to help it hold up to wear. Copper does flow better electrically, but that very small amount of platinum isn't going to cause enough resistance to make a performance difference. In fact, if anything's going to make a performance improvement, it's the platinums. Not only will they last longer, but the stronger and more durable platinum means that they can cut the electrode sharp and it pretty much stays that way, which is good for spark. NGK's V-power plugs take advantage of that (it's not the crappy split fire design). But spark plugs wont really make a difference unless you're replacing worn out plugs.
[Modified by Weston, 12:39 AM 10/28/2002]
Old Oct 27, 2002 | 10:57 PM
o_Rage_o's Avatar
Default Re: Copper Spark Plugs for GS-R? (Weston)
well said...also you might have to make gap adjustments on those non OEM plugs.
-Rage
Old Oct 27, 2002 | 11:33 PM
GSRaCeRbOI's Avatar
the copper plugs are NGK BKR6E-11
Old Oct 28, 2002 | 04:07 AM
SpoonfedDC2's Avatar
I thought that copper was always better because copper is a better conducter than platnium!?!?!?!
Old Oct 28, 2002 | 04:26 AM
Ricky Rojales's Avatar
Default Re: Copper Spark Plugs for GS-R? (SpoonfedDC2)
Please read this again:
Old Oct 28, 2002 | 04:59 AM
TRuST's Avatar
Does everyone still run the same gap after they got a aftermarket Ignition system ?
Old Oct 28, 2002 | 07:30 AM
araknis's Avatar
New User
here's a follow up question then.. would i be better off just using coppers and replacing them every 10,000 miles or whatever it should be or just getting the platinum and changing them very 60,000? is this kind of the same argument as non-syn. motor oil vs. syn. motor oil?
Old Oct 28, 2002 | 07:46 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I run NGK copper plugs and replace them every 10K-15K miles. In the long run it's actually cheaper than buying platinums every 60K miles. For the price of one set of NGK platinum plugs, you can buy at least 5-6 sets of copper plugs.
Bruce Banner
Sep 25, 2009 02:46 PM
Smokey5176
May 8, 2007 05:01 PM
Exeed
Feb 24, 2007 10:39 PM
intek_gsr
Sep 26, 2002 10:21 AM
