[3D files] Honda CRX front and rear big brakes
Old Nov 30, 2013 | 11:49 AM
french_yogi's Avatar
Icon3 [3D files] Honda CRX front and rear big brakes
Hi guys,
I gave the information in my post but thought it will be a good opportunity to share it here with 'craftsmen' !!
For those who can machine and build parts here are some 3D files I've created myself for my own CRX upgrades :
1// Front 282mm big brakes with BREMBO 4 pots calipers - homemade alloy hats and NSX NA1 rotors
2// Rear CRX 260mm big brakes using a new plate and OEM calipers
The front kit is made for a knuckle equiped with OEM 240mm brakes.
You have to check for the plate installation on your rear arms because there is different 'phases' and in France, this fits only phase 1.
I let you guys double check if this is ok or not for your setups
yogi
Old Dec 15, 2013 | 02:31 AM
Walterronny's Avatar
Default Re: [3D files] Honda CRX front and rear big brakes
that's great! what another OEM rotors should be works? or just it's need to be used only these rotos with custom hats? what rims diameter should fits with these front bakes?
Thanks!
Old Dec 18, 2013 | 10:56 AM
Hi,
I must say I created the 3D files and the setup only for this combination of custom hats and rotors.
I don't know if it is possible to fit other rotors but those are the reference for Honda NSX NA1 from STOPTECH (with fully floating system).
This 282mm setup fits under my 15" OZ ultraleggera wheels (without spacers) but the clearance is tight.
Old Jan 4, 2014 | 01:16 PM
crxracer999's Avatar
Great upgrade..........just wondering what prop valve you use in this application
Old Apr 21, 2014 | 08:18 AM
Vagitarian's Avatar
Do the plates for the rear work on a rear disk setup? Using stock crx si calipers? Which rotors are used??
Pics of the rear setup please!
thanks for posting the info!
Old Apr 28, 2014 | 01:53 AM
Hi, sorry but what do you mean by 'prop valve' ?
Yes this kit was built based on a rear 239mm crx DISK SETUP, and it allows you to re-use your stock calipers and keep using the HandBrake perfectly. I did this because I just fully rebuilded my calipers when I developped the kit .
I use European 260mm Honda civic EP discs. They have all same caracteristics as the original one except the new diameter ... perfect. You can usually compare sizes, holes, offset and so on when you order on a spare parts website. It's what I did.
You can go on my full article by clicking on the picture in the first post or by clicking on this one :
rice4life
Aug 12, 2015 08:35 PM
crazyboy
Apr 11, 2010 09:08 PM
blue06civic
Honda Civic (2006 - 2015)
Feb 17, 2007 12:15 PM
george34
Feb 26, 2006 03:11 PM
bseriesboosted
Sep 22, 2003 08:30 PM
