thinner head gasket on H22....anyone know about them?
i was wondering if anyone had ised any of the thin head gaskets that are suppoed to raise compression by like .2 or something. any advantages over stock or disadvantages? thanks
frank
frank
does honda use stretch bolts on the head? the bolts ar almost 8 bucks a piece and i dontknow if i need them or not. also i didnt know if i should replace my oil pump or not. i am gonna do the water pump and t-belt and balancer belt. need help on this guys!! thanks
frank
frank
Spoon makes a thin head gasket for the H22A. I say, if your gasket you have now needs to be replaced, I would get the spoon one.
What did you do in your rebuild? The spoon one should seal correctly and if you're not boosting I don't see a real need to stick to the thicker one. You're going to need adjustable cam gears however and maybe purchase a new tensioner if it can't pick up all the slack depending on what kind of condition it is in.
