Took head off should I do any mods
Old Nov 28, 2013 | 08:33 PM
ucf_motorcycle's Avatar
Default Took head off should I do any mods
First post here:
I have a bone stock 95 GSR...OEM exhaust, wheels, everything.
It has 195,000 miles and has been great a little leaking oil but otherwise everything works.
I replaced the timing belt earlier this year and then after 10,000 miles it broke. It was an OEM Honda belt. It looks all cracked and dry now I figure it must have sat on a shelf somewhere for 10+ years before I put it in.
Anyway I pulled the head fully expecting bent broken valves piston damage etc...well nothing. There was no valve contact at all.
So now that I got the head off what should I do. The car is bone stock and I don't want to throw a ton of money into it.
I thought maybe a thinner head gasket and I definately want to get a stronger timing belt maybe a Gates Racing? Not sure what to get what do you guys think?
Old Nov 28, 2013 | 11:11 PM
Built4Battle's Avatar
Default Re: Took head off should I do any mods
Oem belt is good. Or gates. Just don't get any oil on it. Something in engine oil that eats timing belt and decreases it's life.
And I'd change valve seals for sure and dual valve springs and retainers are always a good idea in case you over rev
Old Nov 28, 2013 | 11:59 PM
standy xsi's Avatar
i usually put secondary rotor's in. and double fin the water pump FTW....
i also give the vtec solenoid a clean so it pops more fresher
stockF22B1
Dec 15, 2012 07:08 PM
nychonda
Feb 22, 2011 02:07 AM
armintheman
Oct 4, 2010 01:05 AM
97gSrkId88
Jul 3, 2006 09:56 AM
Lsos
Jun 7, 2002 11:14 PM
