Honda CR-V & Element 2WD & 4WD Element & CR-V
Buying a crv: crv related issues?
Old Nov 28, 2013 | 06:20 PM
BriantheButcher's Avatar
Default Buying a crv: crv related issues?
Ok looking at buying a 97-01 crv. Anything crv specific I should look out for? Trans issues, rear dif issues anything like that?
Old Nov 29, 2013 | 02:38 AM
Jjbaehr's Avatar
They are great cars, very rare for them to have any major components fail. Just need to make sure it's had a valve adjustment, or do one as soon as you get it. The exhaust valves get so tight that's the seats recede into the head.
Old Nov 29, 2013 | 04:24 AM
noname87's Avatar
Default Re: Buying a crv: crv related issues?
the 97 & 98 V's have 125 hp, the 99-01 V's have 145 hp. that extra 20 is nice to have
Old Nov 29, 2013 | 04:33 AM
PhilStubbs's Avatar
Yea, aim for 99-01. There are no real issues of 1st gen crv's other than the valve thing. You will probably want to do a timing belt right away though unless the seller has proof of doing it recently. Crv's aren't often owned by car enthusiasts and people ignore timing belts a lot
Old Nov 30, 2013 | 09:40 PM
Yea I'm looking for the 99-01 ones. And all general maintenance will be done when purchased. I've owned a lot of Hondas but this will be my first crv.
Old Dec 1, 2013 | 07:11 AM
Sticker Bomb's Avatar
The only real thing to loo at when buying one, is check the drive shaft out. The u-joints light to get play in them, and you can't buy aftermarkets ones the work really.
Old Dec 1, 2013 | 08:09 AM
stangrcr1's Avatar
I just bought a 97 CRV last week. Someone had taken care of it, for the most part. The valves were all in spec, but the timing belt had cracks. And once I got it apart, the water pump was leaking and the front crank seal had just started weeping oil. 181k on it so not surprised. At least I got it cheap. The driveshaft on mine had been redone at some point in the past.
One thing I have noticed on all the used CRVs I looked at was worn out sway bar end links. Not hard to replace, but common to be worn out.
Old Dec 1, 2013 | 12:26 PM
ap1jnky's Avatar
Diff look at the driveshaft but there is replacement u-joint's just did this myself with no problem's using these Rockford Honda u-joint's from drivetrain America you can also find the same one's on ebay that they sell for alil cheaper. Oh and look out for rear quarter rust I was **** about that when I first bought my crv.
http://www.drivetrainamerica.com/p-2...x?cagpspn=pla&
npoutre
10
Jun 20, 2019 01:48 PM
gsrvong
13
Dec 15, 2014 02:03 AM
James89DX
Honda Civic (2001 - 2005)
Jun 24, 2012 05:20 PM
mikester_91
Mar 11, 2008 10:48 AM
BUDtoker
10
Nov 13, 2007 06:37 AM
