crx obd1 b18b1 sputters/boggs
Old Nov 27, 2013 | 09:15 PM
ahtublao's Avatar
Default crx obd1 b18b1 sputters/boggs
alright guys, been having this issue with this swap and i can't figure it out. when it hits about 3k rpms it sputters and i feel like im losing power. when pressing gas the rpm climbs then when it hits 3.5k rpms, it all of sudden gives me power like vtec and then it drives just fine. I have replaced everything that i can think of like, distrubitor, fuel pump, spark plugs and wires, even gave it some seafoam treatment, new map and tps sensors, new throttle body. the funny thing is when i pull the plug to tps, it drives just fine with little hesitation around 2.5k rpms to 2.8k rpms but drives way better then when the tps is plugged in. Need someone to point me to the right direction. even took it to a local shop and they dont know what it is. thanks in advance!!! will try to post a vid soon if i can
Old Nov 28, 2013 | 01:59 AM
ahtublao's Avatar
Default Re: crx obd1 b18b1 sputters/boggs
here is a vid maybe you guys can help me out with. oh btw timing is on and not off. tps was recalibrated to within spec
Old Nov 28, 2013 | 09:05 AM
dueyx99's Avatar
if this was a dpfi car, switched over to mpfi, were the proper wires switched on the tps?
Old Nov 28, 2013 | 06:06 PM
ahtublao's Avatar
its mpfi. hf model. also replaced main relay btw. resistor box been deleted too.
got_no_sol
Mar 12, 2017 07:11 PM
tyvtec23
Oct 25, 2011 11:28 AM
theelemental
Nov 7, 2008 01:37 PM
nolicense526
May 7, 2008 07:35 AM
flatblackhatch
Feb 14, 2006 02:07 PM
