13" Exospeed/Lenso wheels w/slicks, ITR Seats, Hondata S300, Nardi Steering wheel
Means of contact: yzracer323@aol.com
Price: $500
Wheel Brand/Model: Exospeed/Lenso
Diameter: 13"
Lug Pattern: 4x100
Width: 7.5"
Offset: +25
Tire size: 24.5/9.0-13
Tire brand: Mickey Thompson
Tire model: slick
Tread life left: 90%
Pictures:
Price: $350
Wheel Brand/Model: Unknown
Diameter: 16
Lug Pattern: 4x100
Width: 7"
Offset: unknown
Tire size: 215/45zr16 rear, 225/50-16 front
Tire brand: Kumho rear, Hoosier front
Tire model: Ecsta rear, QTP drag radial front
Tread life left: 75% rear, 40% front
Pictures:
Price: $400
Diameter: 15
Lug Pattern: 4x100
Width: 7"
Offset: unknown
Tire size: 205/50zr15 rear, 225/60-15 front
Tire brand: Kumho rear, M&H front
Tire model: Ecsta rear, Racemaster drag radial front
Tread life left: 85% rear, 80% front
Nardi Steering wheel, perfect $250
NRG Short hub for EG,DC/Quick release $140
USDM ITR Front Seats $600, pick up only
s300 w/new boost solenoid $550
Engine
Shortblock: benson sleeved 83mm b18c1, pauter rods, CP pistons $2500
Steel oil pan with -10 bung welded for turbo oil return
*Low miles, under 2000miles, 2 dyno sessions, 5 passes at the track
*Ran Perfectly when last used in July, Removed engine and took head off to to be built, intended to use this as a spare
Victor X intake manifold for GSR, Black wrinke finish $210
Throttle body with 3" Vanjen clamp, spare clamp to attach to your charge pipes $130
Evans tuning stage 3 longblock, rated for 1000hp $4500
*Low miles, less than 1000miles, 2 dyno sessions, never tracked
B18c Block
GSR head, Stock port
83mm AEBS sleeves, Oring’d
CP pistons with HD Wrist Pins /Manley Rods
Comp stage 3 cams *good idle, drives well
Ferrea valves, springs/retainter
Oem 83mm headgasket, ARP head studs
ATI damper
-10an block fittings for catch can
-6an block fitting for water cooled turbos
Bore and Hone
Blueprint and Assembly
ACL Race Bearings
New water pump and oil pump, timing belt tensioner
Moroso oil pan, new gasket
Hasport aluminum mounts EG/DC $220
Mishimoto radiator(thick core)/fan shroud/fan/-16an hoses $350
Turbo Kit
synapse motorsports T4 divided top mount w/ 2 MVS wastegate flanges, Vband downpipe, dump tubes $650
Custom 3” Stainless Vband race Exhaust, TIG welded, Vibrant Race muffler, Has a turndown under the car $150
TiAL MVS 38mm wastegates, Black $220/Ea
Forced Performance hta3586 billet wheel 62mm turbo, Ball-Bearing, T4 divided 1.06 ar housing $1200
TiAL Q blow off valve $210
Custom Intercooler, 12x24x4 core/ 3” Charge pipes, mounting brackets for EG $460
Fuel
id 2000s, run with e85, flushed with pump gas regularly $780
Edlebrock Pro Fuel rail $85
AEM FPR $80
Fuelab 6 micron filter(e85 compatible), black anodized, spare new filter element $80
Billet Fuel filter mount$20
Autometer Boost and Oil press $50/ea
Price: $500
Diameter: 13"
Lug Pattern: 4x100
Width: 7.5"
Offset: +25
Tire model: slick
Pictures:
Price: $350
Diameter: 16
Lug Pattern: 4x100
Width: 7"
Offset: unknown
Pictures:
Price: $400
Diameter: 15
Lug Pattern: 4x100
Width: 7"
Offset: unknown
Engine
B18c Block
ATI damper
Bore and Hone
ACL Race Bearings
Turbo Kit
Fuel
AEM FPR $80
Killspeed93
May 27, 2014 09:52 AM
yzracer323
Wheels
Nov 27, 2013 05:36 PM
