Ideas on amount of power?
Old Nov 26, 2013 | 08:28 PM
lukenordman's Avatar
Default Ideas on amount of power?
I have a quick question. any ideas on what kind of power I would make off this setup? I would also like other ideas on this build if it seems more efficient BUT NO LSV swap comments I WILL NOT build a lsv....onto my idea for the build. hoping for close to 200 anything over is a bonus.
(always been told lsv is a bad engine to build and the engine will fail...unless things have changed that's my reason)
HEAD:
brian cower stage 3 all motor cams
brian cower valve springs and retainers
brian cower valves
toda adjustable cam gears
gates racing Kevlar timing belt
new head gasket
arp head studs
3 angle valve job
port and polish
edelbrock victor x intake manifold
BLOCK:
acl race bearings
arp main studs
weisco forged 12.4:1 pistons
stock b18a1 rods
polished b18a1 crank
ati street super damper crank pulley
skunk2 alpha series stainless header(or have a custom one made.)
FUEL SYSTEM:
grams 550cc injectors
aem high volume fuel rail
aem high volume fuel filter
walbro 255 gph fuel pump
IGNITION:
aem cdi twin fire capacitive discharge amplifier box
aem cdi pencil ignition coils
aem epm optical position module
luke
Old Nov 26, 2013 | 10:49 PM
93egSLEEPER's Avatar
Default Re: Ideas on amount of power?
Lose the intake manifold. Get a performer X. That ignition won't benefit you or this build. Stock is fine. Save your money.
Whoever told you a LSV is a bad setup should be shot. A LSV w/ B16 pistons and ITR cams will run on this motor and be just as reliable.
Old Nov 26, 2013 | 11:15 PM
It was more being shown articles about how lsv's were prone to failure because the ls block was not ment to have the vtec heads. but I'm unsure I feel they were just slapping the heads on because now I see all this talk of actual lsv conversion kits, alright thanks. Any idea what id make hp wise? I was also thinking about maybe scrapping the b18a head for a p8r if I can find another... I found one but it was 800 stock
Old Nov 26, 2013 | 11:33 PM
Runnerdown's Avatar
Old Nov 27, 2013 | 05:05 AM
98vtec's Avatar
moderator emeritus
read the rules of this section. there is no possibly way to guestimate your power output with the variances seen on a dyno and the conditions which could be set at the time.
build it, tune it (dyno), race it, break it. repeat.
marc59
Appearance Build Threads
45
Jul 12, 2015 02:57 PM
Jjmartin1992
Jun 15, 2013 11:48 AM
BigBlock22
51
May 20, 2013 06:12 PM
slick1851
Jul 8, 2010 08:27 AM
satan_srv
Apr 18, 2003 01:31 PM
