got bored and made my own intake(again)!!!
Old Nov 26, 2013 | 06:00 PM
seelback's Avatar
Default got bored and made my own intake(again)!!!
well i've been bored lately so i decided to make another intake for my allmotor b20vtec ek hatch. i have a headlight scoop that i made a couple years ago for the track and a street intake with a velocity stack that goes in the same location as my new intake. reason for building this intake is that i had everything laying around except the vband assembly, my headlight scoop takes alot of time and effort to switch out at the track, and this new intake will outperform my old street intake with the velocity stack. all intakes are 3" piping and this new intake will be my full time street/strip intake. i do all my own fab work except weld. i will post time slips and hopefully vids as soon as i can get to the track. my fastest time on my headlight scoop using 22x8x13 M/T's is 12.53@106mph and my fastest time with my old street intake with velocity stack(ran in the same location as my new intake) using 185x60x13 hoosier r6 radials is 13.3@103mph(but this was a while go with less hp&tq). the aeromotive sticker is covering a hole!!!
headlight scoop
new intake
Old Nov 26, 2013 | 06:08 PM
xbigpitax's Avatar
Default Re: got bored and made my own intake(again)!!!
Did it make a difference?
Old Nov 26, 2013 | 06:26 PM
Tuner Eddy's Avatar
Cool
Old Nov 26, 2013 | 06:34 PM
seelback's Avatar
havent been able to drive it or take it to the track. i just put this on a couple of hours ago. i will go to the track soon and post results up.
Old Nov 26, 2013 | 06:44 PM
KENetics1's Avatar
What does the butt dyno think?
Old Nov 26, 2013 | 06:54 PM
seelback's Avatar
havent driven it yet. i put it on a couple of hours ago and its raining right now. as far as feel, i dont drive the car enough and hardly ever get on it on the street to compare this from my old street intake, but i may do a pull to se how it feels for the heck of it, before going to the track. but i will be comparing it to my headlight scoop at the track. if it performs very close to headlight scoop or outperforms it(which i dont think it will), its a win for me. the whole purpose of this intake was to replace my headlight scoop, which takes time to install and take off at the track and its kinda a pain in the *** and perform pretty close to the headlight scoop. i will post track results as soon as i can.
Old Nov 27, 2013 | 06:45 AM
V-SPEC 1's Avatar
Looking good.
Old Nov 27, 2013 | 07:51 AM
Charlie Moua's Avatar
have you thought of making the shape "collector" rounder vs. boxy?
Old Nov 27, 2013 | 07:52 AM
13173's Avatar
Don't the single TB N/A setups benefit from a longer stepped intake tube?
Old Nov 27, 2013 | 08:31 AM
seelback's Avatar
Yes I have and I still may do it. Last nite I wanted to get it buttoned down. I can still roll the inlet, its not that hard to it.
Old Nov 27, 2013 | 08:41 AM
seelback's Avatar
Yes it should. But theres alot of variables
that determine that but ive had success with this same design intake with a velocity stack instead of a scoop. I am gonna make more of these using 3.5" as well and I may do a test to se which one performs better.
Old Dec 2, 2013 | 08:20 AM
seelback's Avatar
Default Tested new ram air intake with good results
heres the link to my original post about the this ram air intake i just made
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/got-bored-made-my-own-intake-again-3181917/
my fastest 1/8 mile times are in the 7.9's@85mph 1.7 60ft's with my old headlight scoop. went to the track yesterday with great success, with the new intake scoop I was able to run a 7.9@85mph 1.7 60ft. my tuner Vspec1 said the afr's were very close, pretty much spot on between both scoops, and thanks for the awesome tuning as always. soo in the end it was a success. my goal was to have a more convient intake that was permanent and run just as fast as my old headlight scoop.
heres the slip
the whip
Old Dec 2, 2013 | 01:21 PM
luck4rmkc's Avatar
So wait you are going to run that gravel straw on the street with no filtration whatsoever?
You sir have extremely large *****....
Old Dec 2, 2013 | 01:33 PM
lsturbo33's Avatar
I think that is for the track only. The headlight scoop was too much trouble to install at the track. This one should be easier to install and remove at the track. That's the way I understood it.
Old Dec 2, 2013 | 04:59 PM
seelback's Avatar
The whole intake stays in place on the car just have it unhooked from throttle body while running around on the street.
Old Dec 3, 2013 | 06:40 AM
Johnny_Ek's Avatar
i have an ek looking for an intake let me know if your willing to make me one lol
Old Dec 4, 2013 | 08:57 AM
seelback's Avatar
You've been PM'd
Old Dec 4, 2013 | 09:17 AM
EpHatchy's Avatar
how do you like that jdm 4-1 header?
Old Dec 4, 2013 | 12:33 PM
seelback's Avatar
I love it. Great ground clearance, oem quality, and it makes power.
Old Dec 4, 2013 | 12:48 PM
EpHatchy's Avatar
think I might sell my rmf replica and pick one up.ty
seelback
15
Nov 30, 2013 08:20 PM
