wondering what type of pistons these are
some random high compression pistons,
to tell what piston exaxtly this is we will need to both sides of the piston.
definitly not oem honda
maybe some 12:1 cps or so
What motor are those in? Look like CTR's to me. The piston sits below the hole and just the dome is positive so its got to be a B16 or GSR stroke.
Also some builders will sand the sharp edges off CTR pistons when they build a motor.
Look at the OP's pistons...
Then look at this...
Specically the exhaust valve reliefs, different design, appearance, etc.
For sure, theyre not OEM cast pistons. Regardless of what could have been sounded down.
Sanding will only get so far on hard cast pistons and wont get the curves on that piston to be uniform unless it's machined, but if that person spent the money and time machining cast pistons might as well bought some forged in the first place.
clean them up and see if they are coated with anything.
supertech are grey color...
spray some carb cleaner and let it soak then clean with a rag
some pistons have a stamp on top also
MotorMatrix.com
Jul 15, 2003 10:22 AM
