What engine
Old Nov 26, 2013 | 08:31 AM
k_honda's Avatar
Default What engine
Okay I have a 95 accord lx I was wondering what engine would be the best to swap in(more power, easiest, more potential) I keep trying to decide what I want but I keep reading the specs and different motors and then Im back to square one. And do not say k20
Old Nov 26, 2013 | 08:33 AM
Zak325's Avatar
Default Re: What engine
Most H series are common swaps on these. Check the FAQ there are a few tutorials.
Old Nov 26, 2013 | 11:37 AM
MAD_MIKE's Avatar
MM Gruppe B
F22b2 and turbo.
Old Nov 26, 2013 | 12:15 PM
NZXTInerTia's Avatar
Originally Posted by MAD_MIKE
F22b2 and turbo.
I should slap you right around now.
Old Nov 26, 2013 | 01:39 PM
GhostAccord's Avatar
Why not go for the C23B?
Or maybe a K24..... why not?
First things first, what is your budget and how much of this are you able to do yourself?
Old Nov 26, 2013 | 05:25 PM
He said B16, I think he's going to need a lot of help.
Old Nov 26, 2013 | 05:53 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
can't wait to boost so I can troll people on the highway
Old Nov 26, 2013 | 07:21 PM
Especially with that upwards mounted screamer pipe, I've scared a few Prius drivers over the summer.
Old Nov 26, 2013 | 10:11 PM
k_honda's Avatar
I'm leaning between a h22 or f20b but I don't really understand the difference other than a slight advantage in tq to the h22. And I said b16 because I keep hearing that the b series more potential than the others. And lastly k series motors are overrated in my opinion
Old Nov 26, 2013 | 10:39 PM
lol B series wouldn't even move an Accord. Why don't you swap in whatever makes you happy?
Old Nov 26, 2013 | 11:15 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
H22a from the CL1 accord!
Old Nov 27, 2013 | 07:23 AM
mrj_accord's Avatar
stick with the H, more engine parts for it than the F20b or u can go F22B1 and boost
but then again it all depends on
1. HP goal
2. budget
3. reality
Old Nov 27, 2013 | 09:07 AM
k_honda's Avatar
Can't I just use h22 parts on the f20b. I read they are for the most part compatible. My hp goal is between 260-300.
Old Nov 27, 2013 | 11:18 AM
There is no way you're getting there without a ton in engine parts or a turbo.
Old Nov 27, 2013 | 12:10 PM
300whp N/A would require at least 12:1 compression, more than 2.2L displacement, (88/89mm pistons with a 100mm crank and custom rods). minimum 0.400" lift cams, custom exhaust and intake manifold. 300CFM+ head with larger valves, Individual throttles with a custom plenum would be a bonus. an upgraded fuel system, maybe dual stage fuel injection. Along with a good stand alone EMS with a good tuner and not to mention a talented engine builder.
300whp reliably boosted would require a complete bottom end rebuild with forged internals, get rid of the FRM sleeves. A well pieced together turbo system and exhaust. A good engine builder, quality EMS and a qualified tuner.
Old Nov 28, 2013 | 02:11 AM
BeastlyB's Avatar
Ghost are you referring to the CRV F20B type (Similar to the H22) or to the F20B3 similar to the F22B2/3 as I though they could handle 350Hp+ on stock internals or the H22?
Old Nov 28, 2013 | 06:14 AM
mrj_accord's Avatar
keep what u got an boost it!!
putting down 250 to the wheels 300 at crank. installing a new tranny soon, MP6A w/LSD
Old Nov 28, 2013 | 09:55 AM
This dude knows what's up. Boosted F22B1 club reporting in!
Old Nov 28, 2013 | 10:08 AM
Fitz Williams's Avatar
10 Year Member
Is everything there? PS, alternator, AC, ABS ?
Old Nov 29, 2013 | 10:01 AM
Lost Again's Avatar
Sure looks that way....just under the air filter on the turbo it looks like the belt to the ac compressor along with one of the ac lines/hoses.
Old Nov 29, 2013 | 12:15 PM
That turbo must be really tiny to fit under that hood though. I was planning on mounting mine this way, but it wouldn't clear the hood.
Old Nov 29, 2013 | 12:57 PM
EE2bitsk's Avatar
boost what you have or do a k24. k series is not overrated.
Old Nov 29, 2013 | 01:44 PM
MAD_MIKE's Avatar
MM Gruppe B
F22b2 and turbo.
Old Nov 29, 2013 | 01:51 PM
Ferio Wdm Edition
Ks can do 300hp na.....but itll take alotttttt of money lol...
Old Nov 29, 2013 | 04:42 PM
Headswap, wood boost, dat vtak yo.
