VTEC sol connector, any other plugs like it ?
Mine snapped off on the harness side but I can't separate the plug(s) that's how this happened. Are there ANY other plugs like this on 90's-2000 Honda/Acura's ? the junk yard near me(hours drive) barely has any VTEC equipped Honda's. And if you do find one someone's usually picked off the VTEC components ! there's no way I can get this at the dealer as the WHOLE harness would need to be bought/new VTEC sol. i'm not very good(I suck) at re-pining connectors either any suggestions welcome.
thx
here's the pic of the one i'm talking about.
thx
find a yard with the car (and reasonable prices) and phone/email them.
wont cost much to ship and you wont waste gas/time.
http://www.car-part.com/
so in theory I can bypass the plug and it will still work, no ?
will probably be getting a rywire mil-sepc harness cause mine is sooooo brittle and old(94) but this should hold up.
might sound dumb but when you solder your new connection research the term ''thinning'' when soldering. you would be surprised on how many people don't actual know how to solder correctly
Yea, I'm currently in a navy school learning about nuclear grade soldering and specs. Turns out they just stole everything from nasa's specs in the 80s. Pretty minute detail ****.
what's some techniques you have learnt? anything you can relate and ultimately make better on a car?
No its mostly pcb repair type stuff. Good for inside the ecu, not much else, but they really do frown on wire splices of any kind. Its more of a practice type thing, just use a lot of flux and 63/37 w/ resin flux.
idriveadelsol7
Aug 21, 2005 09:46 PM
unbelievableEG
Apr 22, 2005 08:16 AM
