Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
SRS LIGHT
Old Nov 25, 2013 | 09:28 PM
HondaCivicOtwo's Avatar
Default SRS LIGHT
SRS light on in my 2002 civic i reset it and it turned of for a couple a months but just popped back on , anyone else have this problem?
Old Nov 26, 2013 | 06:14 PM
toyomatt84's Avatar
Sanji
Default Re: SRS LIGHT
Have you changed your steering wheel, seatbelts, or anything else SRS-related?
Old Nov 29, 2013 | 07:11 AM
Almighty-Si's Avatar
More than likely the drivers seat belt buckle switch. If you can find someone who can confirm the code, you can take it to the dealer and they will replace it for free. If you can't find someone who can confirm it, the dealer will charge a diagnostic fee but if it is in fact the seat belt buckle switch, you will not have to pay for the repair or diagnostic charge.
Old Dec 3, 2013 | 01:39 PM
darcane's Avatar
Check the SRS code yourself
9-3 is common and indicates the driver's seat belt buckle is at fault. I got mine replaced under warranty about two months ago for this.
Old Dec 9, 2013 | 05:02 PM
lvassar's Avatar
I had the same issue, and turned out to be a failed SRS module. After $100 used module on eBay and about 45 minutes, it was installed. It was a fairly easy install, too.
snuguv
Honda Civic (2006 - 2015)
Dec 2, 2014 03:38 PM
davemem
Honda CR-V & Element
Mar 27, 2013 05:49 PM
my_94teggy
Nov 9, 2008 02:09 PM
vroomboom
Jun 3, 2008 12:31 PM
