Making a tapered air intake tube?
I'm looking into making a tapered air intake tube. Wanting to go from 4" diameter to 3" diameter over a 10" length.
What thickness aluminum sheet should I purchase? I have a local metal distributor who can supply my needs, only I don't know what I need....
How would I go about rolling the sheet without creating a headache? Mind you I have access to a bandsaw and welder(s), but very limited resources to making an aluminum cone.
Thanks in advance.
Thanks in advance.
fab up a sheet metal bender, then measure an 1/8'' or so lengthwise along the material and start bending.
here are some ideas:
http://www.pirate4x4.com/forum/attac...n-100_0501.jpg
http://www.pirate4x4.com/forum/gener...ication-3.html
My recommendation is to make a wooden form, half of what you want the end product to look like. You can cut out the shape from a flat sheet of hardwood, maybe some hardwood ply, but nothing softwood like pine. Make a template from posterboard trace it on to the AL sheet, leave a extra inch all around, that you can trim off later. Buy or make a leather wrapped slapper, clamp the AL sheet down as you go, and hammer the sheet around the buck. Repeat for the opposite half, and weld together. You might have to make segments as you go depending on the shape you want ot make.
I would talk to your metal supplier and tell them what you are making to get the best type of AL to hammer on.
Excellent ideas. I don't wish to hammer form, and I'd like to keep it aesthetically pleasing. After Thanksgiving I will be contacting a local fabricator who has a slip roller. Shouldn't be too difficult with one of those.
If that guys prices are outrageous I will be looking into the 4" pipe with a length -wise cut to make one end 3". Seems like the less costly solution, but we will see after the holidays.
If there are any other suggestions I'm all ears. Thanks
your best bet is to buy a 4" diameter straight and cut and modify. it will be cheapest and you should be able to do it yourself. just draw a straight line down the length, then draw the v from 1/2" offset each side of your centerline on one end to the centerline point on the other end. make your cuts, then squeeze it together to tack weld it.
doing it in a slip roll is the next best option, but 1.5" is a pretty tight radius to roll down to and keep it consistent. it will always want to spring open and may prove a challenge to squeeze together to tack it up.
in for results!
aaron
in for results!
aaron
http://www.burnsstainless.com/rd-300-400-16-6061-l.aspx
Found this little gem. Other than a wait for deliver this seems to be the absolute easiest option available.
Cut it 1/2 way up and you're there?
mild
http://www.mandrel-bends.com/catalog...teel-1536.html
stainless
http://www.mandrel-bends.com/catalog...less-2910.html
mild
stainless
No , however I did speak with a rep at Columbia and they are not able to make the taper out of aluminum. They only offer mild and stainless.
I was told by the Columbia rep to call Coast Aluminum, so I'm now waiting on a call back from them.
It really is looking like the best option is to either take a 4" pipe and cut it down to 3" or take a 3" pipe and open up one end to 4". Either way has me cutting a pipe length wise and either adding or removing material.
Patrick, the only way to make this tube without hacking and welding a 4" pipe is to get a sheet of aluminum, cut it to the desired length and use a slip roller. Same way Justin B made Justin O's intake.
i have used these when making stepped intakes. Maybe they can help you out too.
http://www.racepartsolutions.com/ind...part-solutions
SpoonboyChoi
Aug 8, 2003 07:54 PM
