96 db7 integra partout/ eg apexi ws2 exhaust and more
first off I have a 96 4dr integra that I bought for the swap and brake setup
swap,front and rear disc and seats are gone
it has full black interior that's clean let me know what parts u need and make an offer pm or text 630-677-8779
b series intermediate shaft $30 I have 2
eg dx front spindles complete pretty clean $40
stock eg/dc suspension front and rear springs/struts $60
obd2 b series alternator sold
b16 oil pan with pickup and windage tray $25
b20b oil pan, windage tray and oil pickup $25
karcepts k swap shifter plate with all hardware $80
obd1 pr4 ectune chipped ecu with vtec added from pro function $90
obd1 stock p28 manual ecu $80
obd2 b series ckf crank angle sensor like new with pulley that goes on crank $20
eg hatch apexi worldsport exhaust, comes with complete exhaust with test pipe and also a straight pipe axle back that can bolt up in place of the muffler if you want to run straight pipe header is sold already $350
stainless steel braided clutch line $30
complete eg a/c setup includes lines, a/c compressor and bracket, wire harness, condenser, all that's needed is belt $120
d16z6 engine wire harness $50 has a broken plug which I have it just needs to be swapped out
eg/dc rear aluminum aftermarket mount $25
almost new b series Honda oem water pump and oil pump $60 for both
2.5" turbo downpipe with flex pipe and collector $40
