Parting Out 700+whp Civic, Sleeved engines, Turbo kit, DSS 5.9s, s300, QUALITY PARTS!
Means of contact: PM or Email-yzracer323@aol.com
Price: $varies
Shipping is available(Buyer pays shipping and Paypal fees.)
Custom 3” Stainless Vband race Exhaust, TIG welded, Vibrant Race muffler, Has a turndown under the car $125
Drivetrain
LS trans(Stock Diff) $375
LS/b16 quaife LSD $450
BWR Trans cuff, Used perfect condition (pictured)$Sold
BWR Trans cuff, NEW $180
Spare NEW boost control solenoids $30
Misc.
Alt $50/ea
Half shafts $60/ea
Stock Axles $50/ea
Rear t-bracket, B-series EG/DC $25/ea
Stock integra mounts $50
NEW Stainless steel cluch line kit $55
NEW Brake tuck fitting kit $120
NEW Pushlock vacuum fitting kit $35
-3” stainless exhaust, was on EG hatch, magnaflow muffler $250 picked up only
Price: $varies
Drivetrain
Misc.
Alt $50/ea
Half shafts $60/ea
Stock Axles $50/ea
JUST SENT AN EMAIL REEMB18C1@GMAIL.COM MAY BE INTRESTED IN MORE
Price: $varies
Engine
Shortblock: benson sleeved 83mm b18c1, pauter rods, CP pistons $2500
Steel oil pan with -10 bung welded for turbo oil return
*Low miles, under 2000miles, 2 dyno sessions, 5 passes at the track
*Ran Perfectly when last used in July, Removed engine and took head off to to be built, intended to use this as a spare
Victor X intake manifold for GSR, Black wrinke finish $210
Throttle body with 3" Vanjen clamp, spare clamp to attach to your charge pipes $130
Catch can, Aeroquip lines, valve cover w/ bungs welded $375
*slightly different than pictured, same can, different valve cover and 2 lines run from the front of valve cover, 2 to rear of block.
Spare evans tuning stage 3 longblock, rated for 1000hp $4500
*Low miles, less than 1000miles, 2 dyno sessions, never tracked
B18c Block
GSR head, Stock port
83mm AEBS sleeves, Oring’d
CP pistons with HD Wrist Pins /Manley Rods
Comp stage 3 cams *good idle, drives well
Ferrea valves, springs/retainter
Oem 83mm headgasket, ARP head studs
ATI damper
-10an block fittings for catch can
-6an block fitting for water cooled turbos
Bore and Hone
Blueprint and Assembly
ACL Race Bearings
New water pump and oil pump, timing belt tensioner
Moroso oil pan, new gasket
Hasport aluminum mounts EG/DC $220
Mishimoto radiator(thick core)/fan shroud/fan/-16an hoses $350
Turbo Kit
synapse motorsports T4 divided top mount w/ 2 MVS wastegate flanges, Vband downpipe, dump tubes $650
Custom 3” Stainless Vband race Exhaust, TIG welded, Vibrant Race muffler, Has a turndown under the car $150
TiAL MVS 38mm wastegates, Black $220/Ea
Forced Performance hta3586 billet wheel 62mm turbo, Ball-Bearing, T4 divided 1.06 ar housing $1200
TiAL Q blow off valve $210
Custom Intercooler, 12x24x4 core/ 3” Charge pipes, mounting brackets for EG $460
Fuel
id 2000s, run with e85, flushed with pump gas regularly $780
Edlebrock Pro Fuel rail $85
AEM FPR $80
bosch 044 fuel pumps $150/ea
Aeromotive fuel filters, 100 micron stainless element $75/ea
Fuelab 6 micron filter(e85 compatible), black anodized, spare new filter element $80
Billet Fuel filter mount$20
Drivetrain
LS trans $375
GSR trans fresh rebuilt $500
Mfactory GSR LSD Diff $400
BWR Trans cuff, Used perfect condition $120
DSS 5.9 axles w/ hubs installed in gsr spindles, new wheel bearings $1400
Exedy twin disc, great condition $850
EG/DC Traction bar, forget the brand $100
Electronics
s300 w/new boost solenoid $550
Hondata COP w/custom DR-25 sub-harness, Evans tuning coil plate, Distributor with billet cover,k-series coils $800
Hondata 4bar MAP $90
Spare NEW boost solenoids $40
AEM Wideband gauge(black) with UEGO sensor $130
AEM Boost gauge(black) with sensor $120
AEM Oil Pressure gauge(black) with sensor $120
Misc.
Alt $50/ea
Half shafts $60/ea
Stock Axles $50/ea
NEW Pushlock vacuum fitting kit $40
13” Exospeed/Lenso 4x100 wheels/ 24.5” Slicks $500
15” wheels/tires $400
ITR suede seats w/ red stitching, seat brackets/sliders great condition $600
JDM Center console for EG $150
Autometer Boost and Oil press $50/ea
-3” stainless exhaust, magnaflow muffler $275
Nardi Steering wheel, perfect $250
NRG Short hub for EG,DC/Quick release $140
Selling everything to fund another project. I will update this thread often with new pictures as parts come off the car. Already have a buyer for the rolling chassis. Check back often!
Price: $varies
Engine
B18c Block
ATI damper
Bore and Hone
ACL Race Bearings
Turbo Kit
Fuel
AEM FPR $80
Drivetrain
LS trans $375
Electronics
Misc.
Alt $50/ea
Half shafts $60/ea
Stock Axles $50/ea
