Wheel sizing for track car help
Hi I need help for wheel and tire sizing for scca build I'm doing I have a 99 civic ek coupe with jus racing fenders I'm between 17" and 16" is a built toda motor for power plant also what tire size should I run thanks
well you better look at the rules , i know MOST classes have a aspect ratio/size limit per chassis ir engine modds. deff stay away from 17" wheels on that ek chassis it will limit "race" tires available.
^Exactly what he said. If you are building a car for a race series you should have read the rule book cover to cover before turning a single bolt on the car or buying a single part.
Beyond that, even if this is just an hpde car, I would stay with a 15" wheel. Aside from limiting your availability, price goes way up. Race cars are expensive enough without adding more cost for no good reason.
Costco
Apr 9, 2011 10:26 PM
pandaboi92
Mar 27, 2011 05:30 PM
GotamaHuy
Mar 14, 2010 07:24 PM
