turbo b series valve cover
Old Nov 23, 2013 | 03:12 PM
Umoan4thebone's Avatar
Default turbo b series valve cover
was just wondering what you guys think about using a valve cover that had the baffle removed. has 2 -10an fittings on it, and am also running 2 fittings from the back of the block to a catch can.. buying the valve cover for 10 bucks and he removed the baffle because something fell inside it i guess? any help would be appreciated
Old Nov 23, 2013 | 03:25 PM
TravisBiggie's Avatar
Default Re: turbo b series valve cover
10 bucks is pretty cheap.
I still have my baffle, but I had my buddy put more baffles in there, like so.
ship it to me in seattle and I can have the same baffles welded up. I would say $40-50 total, which would include return shipping.
Old Nov 23, 2013 | 03:37 PM
my real concern is if id be able to use the valve cover like that without having issues, he has the baffle as well, so im sure theres a way to put it back on. and thanks for the offer, i can weld aluminum also, just wanted to see if anyone has run the vc without the baffle using the fittings with or without an issue
Old Nov 23, 2013 | 03:44 PM
of course you can run it without the baffle, the stock vent would not be baffled which is the only down fall. If you are not going to use the baffle I highly recommend baffles like mine.
Old Nov 23, 2013 | 04:17 PM
stock vent is deleted as well lol. he ran a 1/8" plug into it
Old Nov 23, 2013 | 04:36 PM
mechanix619's Avatar
I wouldn't run the cover without the baffle; it's there to serve a purpose. But the only harm would be more oil pushing into the catch can than necessary.
Old Nov 23, 2013 | 05:05 PM
alright, anyone ever re install one??
Old Nov 24, 2013 | 01:19 PM
I also wouldn't trust a reinstall baffle. I've seen some use bolts and nuts to reinstall, which is completely ridiculous; the vibrations would most definitely rattle the nuts loose. I suppose redoing the rivets would work but most of the time when removing the baffle the rivet holes are stretched.
Old Nov 24, 2013 | 04:04 PM
motoxxxman's Avatar
the proper way to reinstall the baffle is to use small allen head bolts with threadlock. of course bolts can rattle loose, that's what threadlock was invented for, duh, lol.
as long as threadlock is used, I have never seen one come loose, ever. let alone actually fall out.
Old Nov 25, 2013 | 11:51 AM
Of course you've never "seen" them come loose, they're hidden from sight until the valve cover is removed, duh, lol.
To each their own, I'm sure 9 out of 10 times everything is just fine with thread lock but I wouldn't play the odds.
I had a valve cover that was sandblasted. My tuner suggested removing the baffle in order to clean out all the sand but they recommended not reinstalling it because it would never hold like factory.
Scott53092
Feb 4, 2014 11:34 AM
Fibercation
Nov 4, 2010 05:46 AM
missionaryrider
Jun 19, 2010 12:51 AM
vtec-adykt
Jan 8, 2010 08:21 PM
89efDUSTY
Nov 26, 2008 10:01 AM
