Speed sensor removal
Old Nov 23, 2013 | 04:53 AM
otisvillain's Avatar
Default Speed sensor removal
I located the one tranny speed sensor:
http://i81.photobucket.com/albums/j2...peedsensor.jpg
What is the best way to remove it? The bolt comes right out but the sensor itself is in there good and tight. I don't want to bust the sensor trying to wrestle it out. Any suggestions?
Old Nov 23, 2013 | 11:03 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Speed sensor removal
If this is one of the NM/NC sensors on the right side cover then you will need to twist the sensor a bit to break it free of the O ring. Rotate it in a direction where the lip will overhang a bit to allow you to prise it up, gently, with a flat head screwdriver. Rotate the sensor while applying upward pressure. It will take a bit of effort to remove. Do not hammer, yank or use pliers on the housing as this can cause it damage or breakage.
Old Nov 23, 2013 | 11:30 PM
klite24's Avatar
+1. I just twist it back and forth with pulling outwards.
Old Nov 23, 2013 | 11:54 PM
holmesnmanny's Avatar
It really does help to actually know what kind of car we're talking about here.
deandbru
May 21, 2015 10:25 PM
prostreetonline
Jul 10, 2004 12:21 PM
