upgraded Throttle Body......worth it?
Im in the process of parts collecting for my build and Im about to order and Skunk2 Pro Intake Manifold and was wondering if its worth it to grab a bigger bore throttle body at the same time? Will it make any type of real gains? I know there are a ton of other things I could spend money on before that but since Im ordering the manifold, Im going to knock it all out at the same time. This will be going on a B16 (2000 Civic Si) daily driven - stock internals - 10psi - hondata s300 - etc....
Thanks
Thanks
If you have money to spare, sure. If you could spend it on a better turbo/manifold/exhaust, no. 60mm is more than enough for a turbo engine, and can be upgraded far easier than anything else.
JforJonathan
10
Apr 10, 2004 12:15 PM
SilverLudeSi
Dec 10, 2001 08:44 AM
