CTR cams vs aftermarket??
Old Nov 21, 2013 | 05:46 PM
alsims86's Avatar
Default CTR cams vs aftermarket??
I am currently running CTR cams but was wondering if making an upgrade will be beneficial for the money? My setup currently is a B18C block LS rods and crank 82.25 mm PCT pistons PR3 head type R intake manifold and throttle body Hondata intake gasket PLM equal length header with 2.5" full exhaust no cat. Will an upgrade in a cam gain anything worth the money I will spend for an upgrade? Or will I need any other or any better supporting mods before I upgrade?
Old Nov 21, 2013 | 06:03 PM
TypeRfit's Avatar
RESIDENT
Default Re: CTR cams vs aftermarket??
What engine management are you running?
Old Nov 21, 2013 | 06:04 PM
alsims86's Avatar
Also forgot to mention I do have dual valve springs and retainers
alsims86's Avatar
Hondata s300 ems
Old Nov 21, 2013 | 09:14 PM
93egSLEEPER's Avatar
82.25mm pct pistons? I don't recall that being an actual size available. You have to be SO close to the aluminum part of the sleeve it's not funny and detonation will crack the wall. Especially with that compression. With any high lift cams you're going to want to clay the motor and check clearances.
Old Nov 22, 2013 | 05:33 AM
alsims86's Avatar
I say 82.25 only bc the top of the piston is stamped .050...I haven't measured them to see and I didn't build it originally I traded and got the setup and have only been inside it to see what it had and to freshen it up with new bearings
Old Nov 22, 2013 | 11:43 AM
They are probably 81.5mm bore.
Old Nov 22, 2013 | 12:33 PM
alsims86's Avatar
I initially thought that but really wasn't sure. So would a skunk2 stage 2 cam be too much for my setup you think?
Old Nov 22, 2013 | 12:52 PM
Like I said in my previous post. You WILL want/need to clay the motor just to be safe. Thse piston domes w/ a high lift cam may run into clearance issues. Last thing you wanna do is kiss a P2V. Your static compression is in the 13:1 range assuming the head was never milled and block never decked and the piston sticks out of the hole 6 thou. You may end up having to retard both cam and ignition timing to the point you can't take full advantage of the cams.
jceltalentoso
Jun 19, 2012 10:31 PM
saemoonyang
28
Sep 14, 2011 10:02 AM
90efSI
Jan 13, 2006 02:32 PM
Driven
14
Apr 4, 2004 10:58 PM
InfamousRS
Apr 20, 2002 05:09 PM
