Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
P0389 339
Old Nov 21, 2013 | 04:17 PM
06 Pilot 1's Avatar
Default P0389 339
My apologies upfront if this has been posted. I'm brand new to this site. I have a 06 pilot. just replaced timing belt w/ pulley tensioner and water pump. Code P0389 and 339 continue to pop up. I've tried changing Crank sensor along w/ the camshaft sensor w/ no luck. I've also changed plugs and adjusted valves. Any help is much appreciated.
Old Nov 23, 2013 | 12:17 AM
slowcivic2k's Avatar
Default Re: P0389 339
Was the crankshaft sensor harness damaged? This is a circuit failure, and if you already replaced the crank sensor, you have a wiring problem.
Brad_and_the_acc
Honda Civic (2001 - 2005)
Jun 16, 2009 01:33 PM
lude98SH
Dec 27, 2007 10:32 AM
philipwk
Nov 29, 2005 07:54 PM
WhippinTheLude
Oct 20, 2004 06:33 AM
