help no brakes
Old Nov 21, 2013 | 01:19 PM
re rex's Avatar
Default help no brakes
My abs light has been on forever and no issues...
I drove to the store and home let it set for about 4 hours go back outside and my brakes will barely stop the car (94 integra with 4 corner disc brakes) so I check the fluid and it was down past the min line so I filled it back up and they are a tad better, but not where they was this morning.
Looked and felt brake lines no issues there calipers are depressing and compressing as should.
What the heck could be causing it? Surely not air in the lines?
Old Nov 21, 2013 | 01:25 PM
B_Swapped93's Avatar
Default Re: help no brakes
Well if it went below the line you have a real leak somewhere and in which air could enter the system. Time to find that leak and bleed the brakes !
Old Nov 21, 2013 | 01:27 PM
re rex's Avatar
Son of a gun anyway I can make it leak and find it?
Old Nov 21, 2013 | 01:30 PM
first visually inspect the lines(from ABS motor also) brake clean will be your friend here, if nothing fill up the master cylinder and have someone pump the brakes just don't let it go empty. I've see them leak around the MC and booster and in the wheel wells(rust is worse there then most places).
Old Nov 21, 2013 | 02:09 PM
re rex's Avatar
Middle of lines between the wheels looks like metal lines are leaking there
Old Nov 21, 2013 | 02:17 PM
wipe it down to confirm.
Old Nov 21, 2013 | 02:19 PM
re rex's Avatar
Its right there in that line
Old Nov 21, 2013 | 02:28 PM
pics ?
Old Nov 21, 2013 | 02:41 PM
re rex's Avatar
Can't really get under waiting on a jack this might be waiting till Saturday cause of no light and well no tools anyway
Old Nov 21, 2013 | 02:43 PM
re rex's Avatar
These are about the best I can get
Old Nov 21, 2013 | 02:47 PM
ohhh it's one of the main ones ****....yah that's a bad leak.
Old Nov 21, 2013 | 02:49 PM
re rex's Avatar
Is it metal like I think it is?
Old Nov 21, 2013 | 03:54 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Yes that's going to be a metal hard line. You can buy a new line from honda which is $$$ or get a new hard line and a tool to bend and flares the lines. Or maybe hit up the u pull it's over there. They always had a lot of Hondas when I lived there.
Old Nov 21, 2013 | 04:28 PM
re rex's Avatar
None there now man Imma just cut it and patch it pretty much with a piece of metal line
Old Nov 21, 2013 | 07:05 PM
ej1995's Avatar
You shouldn't "patch" brake line...EVER! Repair it properly so that you aren't putting yourself and others at danger by driving a car with sketchy brakes.
Old Nov 21, 2013 | 07:12 PM
re rex's Avatar
Ya I'm going to ot right
Old Nov 24, 2013 | 01:48 PM
re rex's Avatar
Is the lines under the car a 3/16?
Old Nov 27, 2013 | 07:07 AM
re rex's Avatar
How do ya get the plastic piece over the lines off?
blkdoutteg
Suspension & Brakes
12
Aug 31, 2015 04:35 AM
type-r-frm-da-808
Suspension & Brakes
Feb 7, 2013 09:38 AM
goldfinger93030
Sep 19, 2010 07:33 PM
maxboost_50psi
Feb 11, 2007 04:37 AM
DA9 Integra
Jan 30, 2005 03:51 AM
