All Motor(GSR) 1993 Civic
I will not part out. Selling for 7000. This car made 260+ whp @ 170lbs torque. You can text me at 559-473-7155 if you want more info. I will send more pics and videos of the motor startup. It ran 11.4 with slicks in 1/4.
ALL MOTOR!
This car is register under non-op.
Clean title
Pink slip in hand
Momo steering wheel
Tokico illumina shocks(all 4) white
Rotor slots
Arp extended wheel bolt pattern
Gator axle
Apexi vafc
Aem air/fuel ratio gauge
Walbro 255 Fuel Pump
Motor
B18c1
Golden Eagle Block Guard
13:1 Compression Ceramic coated pistons
86.5 bore- gsr stroke
750cc injectors
Hasport motor mounts
Skunk2 stage 2 camshafts
Ported/Polished head
Titanium valve springs and retainers
Gsr crank
Skunk2 manifold
Arp head stud
68mm Str throttle body
Golden eagle Pro Series fuel rail
E.n.d.y.n catch can
Msd 8.5mm super conductor spark wire
Moroso catch can filter
Moroso oil pan
Aem trutime cam gears
MSD 6BTM ignition
MSD ignition blaster ss
Transmission
B16 478 final drive (No Grind!)
Type R LSD
Clutchmasters twin disk 5600
Ecu
P28 chip
Hondata s200
Data logging romulator ans burner
Laptop is also included
Wheel
It will either come with GSR Fat Fives or
5 centerline forge wheels with decent tires. I also have the drag wheel with slick that will come with the car.
I know I'm missing a lot of parts.
ALL MOTOR!
Clean title
Pink slip in hand
Momo steering wheel
Rotor slots
Gator axle
Apexi vafc
Motor
B18c1
750cc injectors
Gsr crank
Skunk2 manifold
Arp head stud
E.n.d.y.n catch can
Moroso oil pan
MSD 6BTM ignition
Transmission
Type R LSD
Ecu
P28 chip
Hondata s200
Wheel
