loud thump while turning
hi guys i am hearing a loud thumping sound from right side sometimes when i hit a pothole and now i can feel it when i am going on a straight road around 20,30 km/hour when suddenly i turn my steering towards right i can hear a thump sound . things that have been changed are right shock absorber,both inner and outer tie rods, upper control arm. what can be the problem ?
i have already changed shock absorber ,both inner and outer tierods and upper control arm with upper tie rod. sir can a lower ball joint cause this problem ?
Do you have lowering springs installed?
I have this problem before when the rubber seat between the spring and shock went missing. Every time I turn the wheel to the right there's a loud clunk.
Could be worn lower control arm bushings.
I have worn bushings at the moment and when i turn into my school parking lot i hear a loud thump too.
I realize its my bushings im just waiting to get some cash to press in new energy suspension bushings.
bro i think that the culprit might be these bushings due to the symptoms you have mentioned and also i have changed almost everything on the right front side due to this sound only things left were these LCA bushing and lower ball joint. i have checked lower balljoint and it seems no play in it . so i think its time to save some money for this job lol
Could be your wheel hub/bearings. My wife's, non Honda, car did that since the day we bought it and I couldn't figure it out. Years later when the hubs failed inspection and I replaced them the clunking went away.
may be that can be a problem . however there is no whining or humming sound even at high speeds . can you tell me what are the methods to check a wheel bearing ?
I had the same condition on my DX EK. I was getting a serious squeaking when the wheel was turned at low speeds/at a stop. I just replaced my knuckles with EXs for the larger brakes and the problem went away.
Never had any of that either. You can jack up the right wheel and just grab the wheel at 3 and 9 o'clock positions and see if there is any play without the knuckle moving then do the same holding at 12 and 6.
97Alex
Aug 20, 2005 03:36 AM
