WTB 99-00 Civic Heater/AC parts + misc.
Here is my 'want-to-buy'-list:
Interior heater/AC-related parts found in all 99-00 Civics that came equipped with the double-DIN sized stereo/climate bezel (most parts also found in 97-01 CR-Vs):
77411-S01-A11 Center air duct (located inside the dashboard of any 2dr/3dr/4dr 99-00 Civic if it was equipped with electric climate controls / double din bezel)
79330-S10-A42 Heater blower motor resistor (located on the heater blower unit from any 99-00 Civic that came with electric climate controls / double din bezel OR from 97-01 CR-Vs)
39797-SE0-003 Heater blower motor relay - Denso 056700-7330 (mounted on the bottom of the heater blower unit in 99-00 Civics, but there is also one in almost all Hondas near the cabin fuse box)
79160-S10-A41 Heater Unit auto mode motor with slider, bracket. (located on the heater unit in any 99-00 Civic that came with electric climate controls / double din bezel OR from 97-01 CR-Vs)
32257-S04-A10 Harness that connects to the heater/AC controls (subwire harness B) (99-00 Civics)
32157-S04-A10 Heater harness (subwire harness A) (99-00 Civics) OR just the connectors with pigtails for the resistor, the relay and the auto mode motor. These same connectors are also present on the 'harness A' from a 97-01 CR-V.
90023-P2A-000 x4 The bolts that bolt the A/C compressor to bracket to the block. Probably from all d-series. The four bolts only. Its 8x100 bolts.
95701-06025-08 x5 The bolts that bolt the different A/C hoses and lines to their respective connection points. Its 6x25 bolts. Prob same on all Civics.
77251-S01-A21ZA Double DIN stereo and heater control bezel (any 99-00 Civic that came with the above setup)
And I also need the actual dash controls for the heater and A/C. Different p/n's about, because the controls from the Si (and possibly Ex?) lights up amber, but that doesn't matter to me, so the controls from any 99-00 Civic that came with this 'double DIN' setup will do.
Misc. parts:
D16Y8 throttle cable with bracket.
D16Y8 fuel hose (the one that bolts onto the fuel rail)
53641-ST7-A62 Pinion assembly from a 98-01 Integra Power Steering Rack [regardless of trim and number of doors]
Number 14 on this pic:
OR
53641-ST7-A61 Pinion assembly from a 94-97 Integra Power Steering Rack
Number 16 on this pic:
Including any shim that might be there (part number 5 on above pic).
I would prefer to obtain these parts with as few transactions as possibly, so if you only have like a single bolt from my list, I thank you for your interest, but I'll hold out for someone who has a bit more.
Breaking a single AC-equipped 99-00 3dr DX/CX or 4dr LX/EX/DX or 2dr DX/EX/HX/SI Civic would cover everything on the A/C parts list.
Might add more parts here, but closing in on 48h with 1h sleep, so I'll call it a night and edit later.
If you some of these parts and want to sell them, please PM me with what you got and preferably your asking price.
Misc. parts:
OR
