Ignition wires or not?
Old Nov 20, 2013 | 05:22 PM
CKnight90's Avatar
Default Ignition wires or not?
So when I was looking at my steering wheel(Detachable). I noticed there was 5 wires that weren't being used. 1 Green, 1 gree/red, 1 blue, and 2 gray ones. I don't have a horn, so I assume two are for the horn? But the blue one was screwed in that blank spot to the left of the blue wire.
Old Nov 20, 2013 | 05:23 PM
B_Swapped93's Avatar
Default Re: Ignition wires or not?
the horn one comes out of the SRS harness in the sense it's a "pin" hope you didn't cut it off.
Old Nov 20, 2013 | 05:28 PM
CKnight90's Avatar
The car came with a detachable steering wheel from the PO. Here's a picture..forgot to add it in the post.
Old Nov 21, 2013 | 10:04 PM
slowcivic2k's Avatar
The two rubber ones look like the key sense wires on top of the ignition switch. Not sure of the other two. ABS/Horn?
Old Nov 22, 2013 | 12:03 AM
CKnight90's Avatar
Ok. So the black wires(to the right, taped together) probably are the immobilizer key sense wires, the other 3(if you notice there's a 3rd one hiddin in there(green/red)) are probably abs or horn? How would I go about testing if they're ABS, horn, or key sense wires?
Thanks for the responses :D
Also you think team-integra or clubintegra site guys know more?
Old Nov 22, 2013 | 06:38 PM
NO ! those sites are DEAD even this section is slow...
Old Nov 22, 2013 | 10:36 PM
I would start by finding the SRS connector (yellow if it has/ahd an airbag) under the steering column and looking at the wire colors. The SRS an horn require a clockspring to operate, which is probably missing hence the cut wires.
egrunner
May 12, 2015 02:38 PM
lilpastrana
Apr 6, 2007 11:01 AM
SplitEagle
Oct 26, 2005 05:46 PM
Built4Speed
Dec 26, 2001 09:42 PM
