Passenger side water leak - 94 rs
Old Nov 20, 2013 | 07:14 AM
super jdm yo's Avatar
Default Passenger side water leak - 94 rs
So I just recently bought another 94 integra. I was told that it had water leaks and I did notice the water in the spare tire well. But I am starting to notice a considerable amount of water building up under my passenger seat (car's an rs so no sunroof).
Just wondering if anyone has ever dealt with this before I tear the car apart and throw baby powder everywhere.
thanks
Old Nov 20, 2013 | 08:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: Passenger side water leak - 94 rs
It's not common on the pass. side on an RS, [I have a 94RS].
On an RS the common leaks are the tail light gaskets dry up and leak, you can have a leak at the ant., [top mount] and a problem if drain tube gets unplugged, the other spot is the pressure relief vent just below and behind ant., the rubber flaps can get stuck open.
The best way to find leaks is to remove the interior trim, [all the stuff in the rear, including seat] dry everything up have someone spray a garden hose over the car as you look for the leak(s) from inside the car. 94
Old Nov 20, 2013 | 09:54 AM
Thanks for the reply, I've dealt with the rear leaks with my past two integras. Just thought it was odd to see water build up under the passenger seat (the car's been sitting for the past two months since i bought it and it's autumn here in seattle).
This weekend I plan to take apart the interior and try to find the culprit
Sweetsystem
Jul 7, 2010 07:05 PM
racerjohn
Feb 1, 2010 01:45 PM
Armorzaku
Feb 21, 2009 12:27 AM
milanoredgsr
Feb 24, 2008 11:14 AM
ATS*VEEE
Dec 19, 2005 11:39 AM
