88 civic starter dead
Old Oct 27, 2002 | 05:12 PM
Civic-Stiz's Avatar
Default 88 civic starter dead
when I turn the key it just will click, but sometimes will turn. my guess is the starter, just curious if anyone can give me some info on replacing it aprox. cost, dificulty level and standard hour time thanks in advance!
Old Oct 27, 2002 | 05:14 PM
USDM 4G VTEC's Avatar
Default Re: 88 civic starter dead (Civic-Stiz)
check that ur batt its good!
after that, a starter goes for like 90 bucks (someone please correct me)
dificulty level its about 3 from 1-10.. maybe like 4 for you
it might take me 15 min to change ... and 45 min to you....
just loose 1 nut, pull one plug, take 2 14mm screws, and move the starter out.... thats it...
Old Oct 27, 2002 | 05:19 PM
Civic-Stiz's Avatar
Default Re: 88 civic starter dead (JDM EF9)
thanks alot, where exactly is the starter located?
Old Oct 27, 2002 | 05:22 PM
damn... i guess it will be a 7 now.... jejejeje
look close to the battery on top of the tranny... its under the distribuitor... u can miss it(if u know what a starter look like)
Old Oct 27, 2002 | 05:34 PM
crx(gator)'s Avatar
its right under the intake manifold on the passenger side, try this 1st...take like a pipe and hold it to the started, then hit it the pipe with a hammer a couple of times, see if your car starts then...
Old Oct 28, 2002 | 02:40 PM
PnX-R's Avatar
Before you go out and buy yourself a brand new starter, let me give you some advice on the starter. If the 88 Civic's Starting Circuit is anything close to being the same as the 96 Civic's, I can give you some info on your problem..
Before I begin, I want to let you know that you can go and replace the starter if you to. It's really up to you.. But what I'm trying to do is show you how to systematically test your starter.
First of all, you said that when you turn the key it goes click.. That means that your Starter Solenoid is working. Meaning that the Pull In and Hold In Coils work. But that doesn't mean that you're getting enough power to the starter. So what you're suppose to check next is the battery.. But since it's an 88 Civic, I can assume that there's some starter problems.
Assuming that your battery is fully charged and all.. Since you're planning on swapping out your starter, you might as well open it up and see if you can replace any of the worn parts.. Before doing so, check the connections at the starter and make sure that they're all clean.
Worn parts that you'll probably find are the Brushes on the Commutator. They tend to wear out after awhile. This will cause your starter not to crank over the engine..
Just thought I'd let you know.. I'm just trying to save you some money if possible.. But if you want to know more about how to check starters, look in the Integra Forum.. I pretty much wrote an essay about it.. Look under "Car won't Start".. Good Luck..
Old Oct 31, 2002 | 08:03 AM
2camsaam's Avatar
Default Re: 88 civic starter dead (PnX-R)
Got a starter for sale if you are interested just make an offer. Off of a civic
azandford
Apr 29, 2010 06:03 AM
ek4__
Oct 2, 2006 03:06 PM
Touge Tuning
May 3, 2006 11:14 AM
Sukebei Oni
Mar 16, 2003 01:21 AM
jared3
Apr 23, 2002 06:58 AM
