These parts any good?
Need to replace the timing belt in my CRV soon, so naturally I have been spending a good amount of time researching parts for the job.
Found this kit on Amazon that apparently has all the parts I need for the job at an amazing price. Now the question is, will they be amazing parts?
Based on the description it seems to include all the high-quality brands like Bando belts and even some JDM parts. It just seems to good to be true, because based on my research buying all those parts individually cost a bit more than the 140-ish price tag.
Here is the link:
Also here is the product description:
Here is the link:
TBK Timing Belt Kit Honda CR-V 2.0 1997-2001. Includes: * timing belt * water pump with gasket * timing belt tensioner * timing belt tensioner spring * three accessory drive belts * valve cover gasket * seven valve cover bolt grommets * front crankshaft seal * two front camshaft seals. The tensioner bearing is Koyo made in Japan. The water pump is NPW made in Japan.The drive belts are Bando made in USA. The timing belt is Contitech, Mitsubushi or Flennor. The tensioner spring is factory Honda. The seals and valve cover gasket are Stone or Ishino again made in Japan. This kit will service Honda CR-V's with (2.0L), 4 cylinder engines with a year range of 1997-2001. Services years 1997, 1998, 1999, 2000, 2001.
Here is the link:
Amazon.com: TBK Timing Belt Kit Honda CRV 1997 to 2001: Automotive
Here is the link:
Probably not bad at all and there's a lot there too.
here's oem **** on ebay for more.
http://www.ebay.com/itm/OEM-Honda-Timing-Belt-Water-Pump-Kit-CRV-97-01-Integra-94-01-B18B-B20-/171174751836?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACR-V&hash=item27dacf6e5c&vxp=mtr
Honda Timing Belt Water Pump Kit CRV 97 01 Integra 94 01 B18B B20 | eBay
After looking around a bit more, probably going for that Ebay OEM kit. It is a bit more expensive and doesn't include the accessory belts, but I would rather have a no name alternator belt break then a timing belt on a DOHC engine
k3ntegra
Mar 26, 2014 02:49 AM
