New Honda Motors
Old Nov 19, 2013 | 01:47 PM
DX_JDM_HATCH's Avatar
Default New Honda Motors
Sorry if this has been posted already but what does everyone think about this?
http://world.honda.com/news/2013/413...ine/index.html
Old Nov 19, 2013 | 02:03 PM
TheShodan's Avatar
Moderator
Default Re: New Honda Motors
Interesting.. its about time. Tuning these will be WORLDS different. And the current understanding of static and effective compression ratios will change COMPLETELY..
But not that surprising to say the least.
Old Nov 19, 2013 | 02:10 PM
Freemananana's Avatar
Awesome. It is about time. Factory turbos have been around for awhile. Wish there was more information.
Old Nov 19, 2013 | 02:27 PM
phaphon's Avatar
So 280 he on a civic?
Old Nov 19, 2013 | 02:57 PM
slowman's Avatar
I took way too long
280hp+ on the new 2015 CTR. Not in North America though. Europe.
I'm hoping the next gen Si will get the 2.0L Turbo though. Things would get very interesting.
Old Nov 19, 2013 | 03:13 PM
phaphon's Avatar
Yeah it would be nice.
Old Nov 19, 2013 | 09:22 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
I read rumors about this about a month or so ago. Honda was tested there new civic at the nuringburg (sp) saying they will have the fast ff that hit the track.
Old Nov 19, 2013 | 11:37 PM
wantboost's Avatar
Who is Mr Robot?
looks like they've gone back to some standard things here
IM on the back of the motor, turbo and exhaust manifold are no doubt a one piece casting (think R35, audi/vw, srt4, 335i, etc. turbine housing is integrally cast with the manifold) this means initial turbo upgrades will be centered around stock parts, simply with bigger wheels and machined OEM housings. Eventually companies will develop their own comp. housings as well as manifolds (again, think about the R35 turbo upgrade path here... it's a perfect example of what to expect) turbo is obviously internally wastegated, probably a smaller sized turbo to get the low end torque they were after. Cat is part of the turbine outlet elbow (again, how most recent turbo cars are setup) which again is good for emissions but probably chokes a good bit of exhaust flow, especially right after the turbo... but they did this so the high EGTs light the cat off faster and keep it up to temp, reducing emissions by a good amount..
Glad to see they are using an efficient full sized FMIC from the factory.. I bet those couplers are those crappy flex kind that balloon under pressure
Direct injection... good for emissions and low end/mid range power. Unless someone can crack hondas ecu coding (think GM and HPTuners) then the only way to modify these motors will be by adding additional injectors or converting the motor to port injection
just my observations... Glad to see Honda is joining the ranks of Ford, Buick, Cadillac, Dodge, etc. with their smaller displacement inline turbo motors
Old Nov 20, 2013 | 04:44 AM
Schister66's Avatar
Man U FTW
I'm excited for this. Its about time Honda built a factory turbo engine (that wasnt in a jetski - d16 turbo IIRC)
Old Nov 20, 2013 | 05:03 AM
TheShodan's Avatar
Moderator
Or RDX 2.3Litre motors in which the ECU was just impossible to crack without switching to a standalone.
Old Nov 20, 2013 | 05:12 AM
rich7777's Avatar
Looks interesting. What would be even more interesting was if we could see some of the engineering behind it.
Old Nov 20, 2013 | 07:48 AM
Dark_Teg's Avatar
If Honda would build an AWD turbo car they couldn't make them fast enough.
Old Nov 20, 2013 | 08:17 AM
Schister66's Avatar
Man U FTW
x2...i'd consider ditching my Subaru for that
Old Nov 20, 2013 | 09:14 AM
Is there a timeline as to when we could see this in the states? If the core design is anything like the b or k series I can see huge numbers from this with upgraded turbos
Old Nov 20, 2013 | 11:00 AM
Might just be wishful thinking on my part, but the K was built NA and could handle boost very well. I would think the factory turbo motors would be able to handle quite a bit of boost.
Old Nov 20, 2013 | 11:13 AM
wantboost's Avatar
Who is Mr Robot?
The direct injection, integrated exhaust manifold/turbine, and the ecu software kill any chances of immediate modifications, especially if this isn't a US motor.
Old Nov 20, 2013 | 12:01 PM
1lowek2007's Avatar
Wantboost, it Looks to me like the intake manifold is towards the front of the motor like the k series. No the back...
Old Nov 20, 2013 | 12:28 PM
That's the big thing. Usually the Honda motors are 'off limits' for a few years. There aren't a lot of people who buy brand new cars to scrap the whole thing and put the motor in a 25 year old shell. The exhaust manifold and turbine thing urks me quite a bit. I have seen it before on cars and I think it sucks. Means you have to replace more when they go bad, but I guess it would be fine for rebuilding. And the ECU, chances it will be like the J-series? They have megasquirt or something like that and it does a good job, right?
Old Nov 20, 2013 | 01:04 PM
LightningTeg's Avatar
Community Builder
I'm a little more interested in what the NSX will do
Old Nov 20, 2013 | 03:22 PM
Spunkster's Avatar
You mean something like this: http://www.hondata.com/flashpro_acura_rdx_turbo.html
Old Nov 20, 2013 | 03:41 PM
wantboost's Avatar
Who is Mr Robot?
look closer, it's in the back... exhaust manifold is on the front of the motor....
Old Nov 20, 2013 | 03:42 PM
wantboost's Avatar
Who is Mr Robot?
the silver thing over the exhaust manifold is the intake arm for the turbo... you can clearly see that the cold side intercooler piping goes over the transmission to the throttle body on the intake manifold behind the motor
The 1.5l motor shares the same architecture as the 2.0l... this gives you a clearer view of the intake manifold on the back of the motor, not the front.
It wouldn't work as the way the motor mounts in those chassis there isn't enough room between the engine and firewall for the complex OEM turbo setup
Old Nov 20, 2013 | 03:43 PM
wantboost's Avatar
Who is Mr Robot?
also, it's a vgt turbo. You can see the black actuator mounted to the compressor housing with an arm that goes to the vgt rack on the turbine housing
Old Nov 20, 2013 | 03:48 PM
wantboost's Avatar
Who is Mr Robot?
the new ecu's are more advanced than any honda ecu before it... it has to control direct injection, the variable valve timing, drive by wire, plus boost control and controlling the vgt turbine actuator. No oem honda ecu has anything like megasquirt, not even close. Also this turbo motor probably has some stupid complex auto trans behind it and the ecu has to control that as well... I doubt it will ever have a true manual trans, even in the hype-r, it will probably be a multi-mode dual cluch automatic with a manual, paddle shift option and then standard auto and then a "sport mode" auto.
you might get away with using a piggyback like the AEM FIC4 but I don't believe it can control direct injection... you'd have to add secondary injectors or eliminate the direct injection and convert it to more common port injection. The issue you have there is you'd have to swap the oem ecu back in and revert the motor back to its stock form for it to pass the OBD2 emissions test
Old Nov 20, 2013 | 06:26 PM
1lowek2007's Avatar
huh sure enough, my mistake. little screen on the phone owns me...
