Ckf bypass fail on b20 need help
Old Nov 19, 2013 | 12:51 PM
Midnight_runs's Avatar
Default Ckf bypass fail on b20 need help
Ok so i bought a jdm b20 from the engine depot and dropped it into my 97 ek.
My main problem now is im trying to pass inspection to register my car and i cant cause code 1337 is coming up .
I did the bypass trick for the ckf but the code is still there
I followed .:FFS TechNet:. » ECU & WIRING How-To Articles » CKF Bypass Trick to the teeth and the code is still there
Im using a obd2 p75 ecu
Do i have to drive for a while after doing the bypass for the ecu to read correctly or something ?
Any little bit of help would be appreciated.
Old Nov 19, 2013 | 01:09 PM
instrument's Avatar
Default Re: Ckf bypass fail on b20 need help
did you reset the ecu?
Old Nov 19, 2013 | 01:15 PM
Yea i unplugged it and tryed again and the code is still there
I even tryed to clear it with the scam tool 20x
Old Nov 20, 2013 | 06:02 AM
Bumpppp need help
demael93
Oct 25, 2013 05:27 AM
gshatch
Dec 21, 2008 11:12 PM
1_slo_ef
May 8, 2007 05:27 PM
R6E6I6D
May 3, 2005 07:11 AM
ek44
Dec 10, 2002 06:14 PM
