del sol s d15 wont stop over heating
Old Nov 19, 2013 | 11:40 AM
Jorge4g63's Avatar
Default del sol s d15 wont stop over heating
i just bought my del sol the other day i changed the radiator, thermostat, radiator hoses, and put in a fail safe thermostat.... i drove the car home 3 hours before i put in those new parts but when i was driving itd stay cool and then when i stop at a light itd over heat but now when i changed everything it just over heats but when i rev up the car it starts to get cool any ideas why its overheating also i know the fan comes on but still over heats.
Old Nov 19, 2013 | 12:19 PM
Former User's Avatar
Default Re: del sol s d15 wont stop over heating
Did you bleed the cooling system? Is the radiator and reservoir topped off with coolant?
Old Nov 19, 2013 | 12:24 PM
Jorge4g63's Avatar
no i have not bleed the cooling system and yes its topped off
Old Nov 19, 2013 | 12:28 PM
Bleed it.
Old Nov 19, 2013 | 12:34 PM
Jorge4g63's Avatar
maybad sorry i did bleed the cooling system i just wasnt sure
Old Nov 19, 2013 | 02:21 PM
Jorge4g63's Avatar
ttt still need help!
Old Nov 19, 2013 | 03:18 PM
ej1995's Avatar
ok, so that tells you 1 of 2 things, either your temperature sensor is not providing the proper information back to the guage, OR, because its rpm based, the coolant is not moving enough at idle to keep the system cool (water pump or blockage somehwhere)
Old Nov 19, 2013 | 06:57 PM
Jorge4g63's Avatar
ok thank you nothing is blocked so its most likely the water pump just ordered the whole kit gonna re do the timing will were at it
houghton
Dec 21, 2010 03:49 PM
emskiii
Jun 17, 2009 09:58 PM
wtfitzphat
Jan 19, 2009 05:59 AM
dangmedcalf
Jun 12, 2008 12:58 PM
Civic1992DX
Aug 3, 2002 10:49 AM
