Brian Crower cams valve adjustment?
Old Nov 19, 2013 | 01:37 AM
justinwallen12345's Avatar
Default Brian Crower cams valve adjustment?
So I have Brian Crower 272 cams in my b20 with LS head and Crower springs and retainers also! But my question is, is my valve lashing going to be any different from stock specs? Because I can't find anything on if I need to adjust them any differently some input would be greatly appreciated!
Old Nov 19, 2013 | 05:41 AM
kyden's Avatar
Default Re: Brian Crower cams valve adjustment?
it's on the website. and they don't make 272s.
Old Nov 21, 2013 | 11:17 PM
slowcivic2k's Avatar
Any time a cam is replaced you must check the base circle diameter by checking the lash. Failure to do so may result in damage or excessive lash which may produce noise.
justinwallen12345
Nov 19, 2013 01:56 AM
revhardallday
Nov 26, 2008 03:08 PM
exownzu
Sep 30, 2006 08:58 AM
Home Wrecker
Aug 18, 2006 05:50 AM
mugenracer
Mar 13, 2005 09:29 PM
